amp with factory infinity system
twinmill28
Posted: November 02, 2008 at 12:51 AM / IP Logged
I have a 2002 Chrysler Town & Country with factory Infinity stereo (I think it's factory upgraded w/seperate tweets in back and front). I want to add a Kenwood amp running 2ea 10" Kenwood subs (dual voice coils), and tap off of the factory head unit for the amp A & B channel incoming signals. The amp is a 4 channel, bridgeable to 2 channel-4 ohms, which I have wired as such now. What factory speaker wires can I tap into for good signal from the head unit to the amp? I ran 4pr/18 gauge speaker wires from what I thought was a good signal from the long rectangular connector on back of the head unit but when I ran the system up the factory speakers clipped a couple of times then cut out altogether, leaving the subwoofers to play alone. I pulled the power to the amp and the factory speakers came back on. There is another, square, plug on back of the head unit, does that have speaker wires that I can tap into for signal to the amp with no issues?
fiberglasslvr
Copper - Posts: 116
Posted: November 02, 2008 at 3:44 PM / IP Logged
there is a stock amplifier in this car to get a good signal for your subs you will have to tap the speakers coming out of the amp. dont quote me on this but i believe the amp is under the pass seat
good luck
in process of changing everything
twinmill28
Posted: November 04, 2008 at 3:00 AM / IP Logged
Thanks, I looked under the seat, nothing but power seat stuff and a heater duct for the back seat.  I think the factory amp is built into the head unit-it has a huge heatsink attached to it.  Anybody else with any ideas/suggestions?
Platinum - Posts: 13,725
Posted: November 04, 2008 at 3:08 AM / IP Logged
Some of the Infinity systems have the amplifiers built onto the speakers.
Thursday, February 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
