2009 ford flex, alarm/remote start wiring
irishqb
Posted: November 05, 2008 at 7:50 PM / IP Logged
I jsut purchased a 2009 Ford Flex.  I need help finding the wiring diagram for the vehicle to hook up a Clifford Avantgurad 5  alarm and remote start system. Thanks for your help.
Platinum - Posts: 13,726
Posted: November 05, 2008 at 8:32 PM / IP Logged
Alarm Info Note on all door trigger states that the door pins rest at (-) when door closed, when door is opened it goes to open circuit.
     Battery          BLUE/RED          (+)          IGNITION SWITCH HARNESS
     Ignition 1          WHITE/ ORANGE          (+)          IGNITION SWITCH HARNESS
     Starter 1          BLUE/WHITE          (+)          IGNITION SWITCH HARNESS
     All Door Trigger          GRAY/VIOLET          (+)          SJB CONNECTOR C2280A PIN 9
     Domelight Super          GREEN/ BLUE          (-)          DOME LAMP SWITCH
     LF Latch          GREEN/ PURPLE          (-)          DRIVERS KICKPANEL OR SJB CONNECTOR C PLUG14
     RF Latch          WHITE          (-)          FRONT PASSENGER KICKPANEL OR SJB CONNECTOR C PIN 2
     LR Latch          GREEN          (-)          DRIVERS KICKPANEL OR SJB CONNECTOR C PIN 3
     RR Latch          YELLOW          (-)          PASSENGER KICKPANEL OR SJB CONNECTOR C PIN 15
     Trunk Trigger          GRAY/ORANGE          (-)          DRIVERS KICKPANEL OR SJB CONNECTOR C PIN 16
     Hood Trigger          BLUE/ORANGE          (-)          HOOD SWITCH OR SJB CONNECTOR F PIN 7
     Alarm Disarm          GREEN/ VIOLET          (-)          DRIVERS KICKPANEL OR SJB CONNECTOR C PIN 8
     Alarm Arm          BLUE/BROWN          (-)          DRIVERS KICKPANEL OR SJB CONNECTOR C PIN 9
     Parking Lights          VILOET/WHITE          (-)          SJB CONNECTOR C2280E PIN 6
     Low Crr Pk Lights          GRAY          (-)          AT HEADLIGHT SWITCH
     Audiovox Products          FLTBF
Remote Start info
     Accessory 1          VIOLET/GREEN          (+)          IGNITION SWITCH HARNESS
     Anti-Theft Type          FORD PATS® OR SECURILOCK® VEHICLE IMMOBILIZER
     Anti-Theft Descript          THE KEY SENDS AN RF SIGNAL TO THE BCM MODULE THROUGH AN ANTENNA LOCATED AROUND THE IGNITION CYLINDER
     Key Sense          BLUE/GRAY          (-)          IGNITION SWITCH HARNESS
     Speed Sense          BROWN / GREEN          (AC)          AT THE PCM 50 PIN CONNECTOR PIN 14
     Low Crr. Pk Lights          GRAY          (-)          AT HEADLIGHT SWITCH
     Brake Lights          VILOET/WHITE          (+)          SJB CONNECTOR C2280B PIN 40
     Reverse Lights          GREEN/ BROWN          (+)          IN HARNESS IN DRIVER KICKPANEL TO REAR
     Horn          BLUE/WHITE          (-)          STEERING COLUMN HARNESS
     Anti Theft RX          PURPLE / GRAY          DATA          PATS TRANSCEIVER 4 PIN PLUG PIN 3
     Anti Theft TX          YELLOW/ORANGE          DATA          PATS TRANSCEIVER 4 PIN PLUG PIN 4
     Rear Defrost          WHITE/ ORANGE
Door Lock info Power lock wire also in drivers kick panel
     Door Lock Circuit          3 WIRE NEGATIVE
     Power Unlock          YELLOW/VIOLET          (-)          DRIVERS KICK PANEL
     PowerLock          BLUE/GREEN          (-)          SJB CONNECTOR C2280C PIN 17
     Driver Mtr Unlock          BLUE/GREEN          (REV)          DRIVERS KICKPANEL
     Driver Mtr Lock          GRAY/BROWN          (REV)          DRIVERS KICKPANEL
     Pas Mtr Unlock          VIOLET/GRAY          (REV)          DRIVERS KICKPANEL
