Foglights independent
dazed
Member - Posts: 22
Posted: March 14, 2003 at 11:00 AM / IP Logged
I have a '93 MX6 and my foglites only work when I have the headlites on. What would be the easiest way to make
them/the switch on the dash independent of the headlights? I want to avoid having to run a separate wire thru the firewall......any suggestions?
Ronald Mark
Copper - Posts: 66
Posted: March 14, 2003 at 12:01 PM / IP Logged
This will be a little tricky without a diagram. The fog lite switch controls the fog lites, so one wire will go out to the lites, the other will be powered by the headlites switch. Take the one that is powered by the headlite switch and connect it to switched power or constant. If the switch is lighted, you will have 1 or 2 other wires, use a DMM to determine.
beerstud136
Copper - Posts: 100
Posted: March 18, 2003 at 11:14 AM / IP Logged
what the hell, just re wire them from the lights themselves to a new switch somewhere on your dash. i know in 93-97 mx6's there are lots of un used knock out panels. just an idea
