08 jeep liberty remote start/alarm
Welcome Guest :)
spunky9198
Member -
Posted: November 11, 2008 at 5:31 PM / IP Logged
If anyone could provide me any help it would be greatly appreciated. I Need Information on A 2008 Jeep Liberty Sport. Wire color and location to install a remote start and alarm.
ckeeler
Gold -
Posted: November 12, 2008 at 12:56 PM / IP Logged
| 12 VOLT CONSTANT | BLUE/RED (+) | IGNITION SWITCH HARNESS | |
| STARTER | N/A SEE NOTE * | | |
| STARTER 2 | N/A | N/A | |
| IGNITION 1 | PINK/WHITE (+) | IGNITION SWITCH HARNESS | |
| IGNITION 2 | N/A | N/A | |
| IGNITION 3 | N/A | N/A | |
| ACCESSORY /HEATER BLOWER 1 | N/A SEE NOTE * | | |
| ACCESSORY /HEATER BLOWER 2 | N/A | N/A | |
| KEYSENSE | N/A | N/A | |
| PARKING LIGHTS ( - ) | N/A | N/A | |
| PARKING LIGHTS ( + ) | WHITE/ VIOLET (+) | LOW IN DRIVERS KICK PANEL | |
| POWER LOCK | VIOLET/DARK GREEN SEE NOTE ** | IN DRIVERS KICK PANEL | |
| POWER UNLOCK | SAME AS LOCK WIRE SEE NOTE ** | IN DRIVERS KICK PANEL | |
| LOCK MOTOR WIRE | N/A | N/A | |
| DOOR TRIGGER | SEE NOTE *** | | |
| DOMELIGHT SUPERVISION | YELLOW/WHITE (+) | IN DRIVERS KICK PANEL | |
| TRUNK RELEASE | N/A | N/A | |
| SLIDING POWER DOOR | N/A | N/A | |
| HORN | DARK GREEN/ PURPLE (-) | AT STEERING COLUMN HARNESS | |
| TACH | N/A | N/A | |
| WAIT TO START LIGHT | N/A | N/A | |
| BRAKE | WHITE/ TAN (+) | AT SWITCH ABOVE BRAKE PEDAL | |
| FACTORY ALARM DISARM | N/A | N/A | |
| ANTI-THEFT | TRANSPONDER ANTI-THEFT | TRANSPONDER @ IGNITION SWITCH TUMBLER | |
| NOTES |
NOTE * THIS VEHICLE HAS A SPECIAL IGNITION THAT REQUIRES A BYPASS PKUCH2X FOR REMOTE START. NOTE ** THIS VEHICLE USES A SINGLE WIRE DOORLOCKING SYSTEM THAT REQUIRES 100 OHM RESISTOR FOR UNLOCK AND 330 OHM RESISTOR FOR LOCK.NOTE *** THE LEFT FRONT DOOR TRIGGER IS VIOLET (-) IN DRIVERS KICK PANEL. THE RIGHT FRONT DOOR TRIGGER IS VIOLET/WHITE (-) IN PASSENGER KICK PANEL. THE LEFT REAR DOOR TRIGGER IS VIOLET/GRAY (-) IN DRIVERS KICK PANEL. THE RIGHT REAR DOOR TRIGGER IS VIOLET / YELLOW (-) IN PASSENGER KICK PANEL. USE ALL 4 WIRES AND DIODE ISOLATE EACH. |
Wednesday, April 1, 2026
• Copyright © 1999-2026 the12volt.com, All Rights Reserved
• Privacy Policy & Use of Cookies
