Posted: November 15, 2008 at 8:36 PM / IP Logged
Posted: November 15, 2008 at 10:54 PM / IP Logged
Posted: November 16, 2008 at 7:40 AM / IP Logged
Posted: November 26, 2008 at 9:33 PM / IP Logged
Posted: November 26, 2008 at 9:36 PM / IP Logged
Sunday, March 22, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
Just change the RC values and you should be all set then-
By the way.. the 47uF cap is NOT the timing cap, it's for power filtering. The cap you want to change is the little yellow thingie.
Double check it and trace it to pins 6 and 7 of the IC. Resistor is across the two pins, and the cap is connected to pin 6.
