speed wire location for a 2005 tacoma
lowroller94
Member - Posts: 10
Posted: November 20, 2008 at 2:19 PM / IP Logged
I installed a new Double Din Eclipse Nav unit in a 2005 Tacoma Crew Cab... Does anybody know where the speed wire is located inside the truck, and how would you test it if found?
do it myself inc.
Platinum - Posts: 13,726
Posted: November 20, 2008 at 6:49 PM / IP Logged
Speed SenseVIOLET/WHITE(AC)AT ECM MODULE BEHIND GLOVEBOX
Also found in harness going to instrument cluster.
It is a pulsating DC voltage, it will show up on your digital volt meter as an AC voltage.  The faster you drive the truck the higher the voltage will read.
lowroller94
Member - Posts: 10
Posted: November 20, 2008 at 11:26 PM / IP Logged
Thank you, I really appreciate it... Good info...
do it myself inc.
