heated seat wire in h2
hum dinger
Member - Posts: 26
Posted: November 23, 2008 at 5:23 PM / IP Logged
Hey guys do you know what wire will activate Heated seats in an 2003 H2?  I know they will be turned on automatically when It's 32 degrees but I want to be able to turn them on when it's 40-50 degrees if I want.  Thanks
KarTuneMan
Platinum - Posts: 7,056
Posted: December 05, 2008 at 7:23 PM / IP Logged
In each door at the switch assembly. The drivers is blue, and the pass. is gray. The require a (POS)+ trigger.
hum dinger
Member - Posts: 26
Posted: December 05, 2008 at 7:52 PM / IP Logged
Thanks KarTuneMan
