2006 ford freestyle se
wardyl
Member - Posts: 14
Posted: December 05, 2008 at 11:24 AM / IP Logged
I am looking for wiring information for the car above. I am planning ot install a remote start for a christmas present.
I looked on the database and it wasn't in there. Any help would be great.
Warren
ckeeler
Gold - Posts: 1,461
Posted: December 05, 2008 at 8:04 PM / IP Logged
12 VOLT CONSTANT  RED (+)   IGNITION SWITCH HARNESS
 STARTER DARK GREEN (+)  IGNITION SWITCH HARNESS
 STARTER 2 N/A
 IGNITION 1 LIGHT GREEN/ PURPLE (+) IGNITION SWITCH HARNESS
 IGNITION 2 N/A
 IGNITION 3 N/A
 ACCESSORY /HEATER BLOWER 1 GRAY / YELLOW (+)  IGNITION SWITCH HARNESS
 ACCESSORY /HEATER BLOWER 2 N/A
 KEYSENSE N/A
 PARKING LIGHTS ( - ) BLACK/ LIGHT GREEN (-)  @ SJB, Connector D, Pin 26, See NOTE *1
 PARKING LIGHTS ( + ) BROWN / WHITE (+)  @ SJB, Connector E, Pin 22, See NOTE *1
 POWER LOCK PINK / YELLOW (TYPE B)  @ SJB, Connector C, Pin 3, See NOTE *1
 POWER UNLOCK PINK/LIGHT GREEN (TYPE B)  @ SJB, Connector C, Pin 18, See NOTE *1
 LOCK MOTOR WIRE PINK/BLACK (+)  IN DRIVERS KICK PANEL
 DOOR TRIGGER BLACK/ LIGHT BLUE (+)  @ SJB, Connector E, Pin 7, See NOTE *1
 DOMELIGHT SUPERVISION USE DOOR TRIGGER, Requires Relay
 TRUNK RELEASE N/A
 SLIDING POWER DOOR N/A
 HORN DARK BLUE (-)  @ SJB, Connector B, Pin 7, See NOTE *1
 TACH Any wire that is NOT RED  @ any IGNITON COIL or FUEL INJECTORS
 WAIT TO START LIGHT N/A
 BRAKE RED / LIGHT GREEN (+)  @ SJB, Connector A, Pin 8, See NOTE *1
 FACTORY ALARM DISARM  LIGHT BLUE/BLACK (-)  @ SJB, Connector C, Pin 4, See NOTE *1
 ANTI-THEFT FORD'S SECURILOCK ANTI-THEFT TRANSPONDER SYSTEM  TRANSPONDER @ IGNITION SWITCH TUMBLER
NOTES
 NOTE *1 The SJB (Smart Junction Block) is the FUSE/RELAY BOX under the Drivers side Dash.
wardyl
Member - Posts: 14
Posted: December 08, 2008 at 8:02 AM / IP Logged
Thanks for your help
Warren
Monday, February 16, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
