adding remote starting to alpine sec 150r
runovrm
Posted: December 05, 2008 at 2:23 PM / IP Logged
Hello,
I would like to add Remote Starting to my 1999 GMC, K-1500 (4X4) Suburban (with Passlock II) that already has a fully functional Alpine SEC-150R alarm system on it.
When I bought the Alpine system (years ago), I recall being told that a Remote Starting Module was available that could be added.  Unfortunately, I cannot find such a module anywhere.
Is there a workable solution that can add this function (& others) to my present system?  When contemplating the possibilities it would be good for the group to know that I want to avoid using anything more than one single remote to control all functions.
Thanking you in advance...
Runovrm
Chris Luongo
Platinum - Posts: 3,746
Posted: December 05, 2008 at 5:31 PM / IP Logged
I'm sure the Alpine must have some kind of auxilary output, for example, to open the trunk on a sedan.
Most (but not all) remote starters have an activation input, that when triggered, turns on the remote starter.
You could just buy any brand of remote starter you want, install it, and connect the activation input to the Alpine's auxilary output.
However, surely the Alpine unit doesn't have great range. Can you arm/disarm from inside your house? If not, you won't be able to trigger the remote start, either. And you surely won't be able to remote start from the mall or supermarket, the range won't be enough.
On top of that, you'll have to use relay(s) to interrupt the Alpine's shock sensor during remote start, so the vibrating engine won't set the alarm off.
If it were my truck, I'd pull the alarm out, and install an alarm/starter combo. It would only cost maybe $20-40 more than a standalone remote starter, and save you a lot of extra work and parts.
runovrm
Posted: December 18, 2008 at 11:20 AM / IP Logged
Chris,
Thanks for the reply.  Sorry it took me so long to get back to you but work...
Yes, the Alpine does have auxilary outputs.  In fact there are three that aren't being used.
As far as distance is concerned, this alarm is pretty good.  100 yards or so.  I can arm/disarm it from inside the house, from across the street, even from inside my business office.
All that said, save for the need to use use relay(s) to interrupt the Alpine's shock sensor, I might think it a good enough system to go for the modification.  What do you think?
If you were to go mod, which remote starter kit would you use/recommend?
If you were to go full rip and reinstall, which alarm/starter combo would you use/recommend?
Thanks!
Wednesday, May 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
