09 chevy hhr remote start issue
desh187
Copper - Posts: 310
Posted: December 09, 2008 at 12:02 AM / IP Logged
Installed a 2way Black Widow (z5) with a Can SL2 bypass unit in a 2009 Chevy HHR about a month ago.
Every now and then when the Auto Start is used,when the vehicle is driven away,the security light remains on until the vehicle is restarted with the key.
Any suggestions will be appreciated.Thanks.
ceasar326
Copper - Posts: 239
Posted: December 09, 2008 at 1:20 AM / IP Logged
Check your CAN SL2 could be a bad bypass module, also your ground. I had same issue except mine i would programe it and lose programing after an hour, i would programe it again and same deal. After changing modules no more problem. Hope this helps.
