02 trailblazer xk01 and python 872
rmm7bb
Posted: December 24, 2008 at 2:43 PM / IP Logged
I just installed a python 872 and xk01 in my 02 trailblazer.  The xk01 says that it will control the hatch via the datawire and it does not.  i was wondering if this is uncommon or if I need to diode isolate.  My xk01 did freeze up initially so I am unsure.
Also, I can not find the correct parking light wire.  I have found three brown wires in the kick panel but they are not controlling the lights.  Is there a specific place I can go that will work for sure?
Thanks for the help.
ckeeler
Gold - Posts: 1,461
Posted: December 24, 2008 at 5:14 PM / IP Logged
there is also a gray/black wire at the switch and the BCM, they are negative trigger.
Mike M2
Platinum - Posts: 2,652
Posted: December 24, 2008 at 5:59 PM / IP Logged
I agree, gray/black at the back of the switch, negative. There are two, it's the one on the bottom row...
Mike M2
Tech Manager
CS Dealer Services
kgerry
Platinum - Posts: 3,455
Posted: December 26, 2008 at 1:52 PM / IP Logged
in the "brown" plug  if i remember correctly
Kevin Gerry
MECP First Class Installer
Owner/Installer
Classic Car Audio
since 1979
rmm7bb
Posted: December 26, 2008 at 11:18 PM / IP Logged
Ok I have it all installed with the parking wire hooked up to the neg BLACK/ grey wire on the headlight switch.  Except now my HU seems confused.  The illumination wire is hooked up to the BROWN / white wire at the headlight switch.  The radio will jump in and out of night mode when the headlights are on and this wasn't happening until I installed the alarm.  The wire is not loose and it always fixes itself, but every now and again it jumps to day mode for about ten seconds.  What could the problem be?
Also, when i remote start the alarm goes off after a few seconds.  The alarm shows that it is zone 1 which is my audio sensor.  I was wondering how common it was for music to set off the sensor since it would be playing when the truck is started.
Monday, May 13, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
