2009 acura tsx wiring diagram with pics
tedmond
Gold - Posts: 4,610
Posted: January 08, 2009 at 8:01 PM / IP Logged
Thought I would share the new wiring diagram for the 2009 Acura TSX with pictures.
Here is the download link from the site: https://www.the12volt.com/installbay/file.asp?ID=743
Incase that doesnt work, go to DOWNLOADS, TECH MISC, Look for 2009 Acura TSX wiring diagram with pictures or search it.
loneranger
Copper - Posts: 572
Posted: January 08, 2009 at 8:03 PM / IP Logged
Thanks, tedmond. Wow, nice pics from Fortin.
I'm a little confused about pins 79 and 81. Do you have any information?
tedmond
Gold - Posts: 4,610
Posted: January 08, 2009 at 8:20 PM / IP Logged
The pictures are in the same order as the wiring colour in the chart. I mentioned to ignore the numbers that pinpoints the wires. I dont know why they put ramdom numbers. I also have the diagram for the 08 Accord but i dont know where i saved it too. Same with that one, the wire numbers are really off. Not too sure if this is a way for them to keep track of info or something.
as for the moon roof open/close, im not 100% positive, but it says to diode isolate so that is straight forward, since there is BLUE, GRAY, and PURPLE
you will diode isolate meaning from your unit, sending a negative latched signal to relay then to the BLUE and PURPLE with diodes so they do not backfeed on eachother. Im sure you will need to send a neg signal to both the wires. Same concept for GRAY and PURPLE.
robertsc
Copper - Posts: 337
Posted: January 08, 2009 at 8:32 PM / IP Logged
you think they will like you posting that here seeing you need a serial number to access that info now
loneranger
Copper - Posts: 572
Posted: January 08, 2009 at 8:38 PM / IP Logged
tedmond wrote:
... as for the moon roof open/close, im not 100% positive, but it says to diode isolate so that is straight forward, since there is BLUE, GRAY, and PURPLE ...
Ah. I wasn't sure if they meant BLUE/PURPLE and GREY/PURPLE. That's where I was confused.
I don't know but, it's saved on my archives now.
tedmond
Gold - Posts: 4,610
Posted: January 08, 2009 at 8:43 PM / IP Logged
well, technically i already paid for the serial numbers. Fortin ships serial numbers with their bypasses and a friend of mine is a Fortin dealer, so he has an account that has all the diagrams to access for free. He gives me a wack load of serial numbers that he has for the bypasses, since its useless to him (has full access to fortin) so i use them for diagrams when i need them :)
tedmond
Gold - Posts: 4,610
Posted: January 08, 2009 at 8:48 PM / IP Logged
also, its already uploaded to the site so oh well. If mods think it isnt okay then by all means discard the file for me(since i dont think i can remove files)
tedmond
Gold - Posts: 4,610
Posted: January 10, 2009 at 5:19 PM / IP Logged
key ktm and howie, you think the fortin diagrams are better? or comparable to astrochart or directechs
their tag line is "for installers, by installers"
