'96 infinite i30 wiring need help
sogoku
Posted: March 17, 2003 at 9:55 PM / IP Logged
Someone pls help. I need help on locating the tachometer wire for remote starter installation. Thanx
lagatbezan
Copper - Posts: 117
Posted: March 17, 2003 at 11:15 PM / IP Logged
i believe the tach wire is WHITE/ green located in the ecm = in the front of the center cosole on the transmission hump.  remove the small black panel infront of the ceter console on the passenger side; the wire should be in the middle row,7th one in from the left ;WHITE/ green wire. let me know if this helps.
Ryan
drvnbysound
Silver - Posts: 289
Posted: March 17, 2003 at 11:25 PM / IP Logged
From the program that I have, it reads, WHITE/ green BEHIND center console, thought I should add my 2 cents
drvnbysound@aol.com
sogoku
Posted: March 18, 2003 at 8:54 AM / IP Logged
thanx lagatzbezan and drvnbysound for the info.  i will let u know if i can find all the wires to install.  thanx
Tuesday, February 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
