wiring leds
kandyman67
Posted: January 14, 2009 at 5:57 PM / IP Logged
Prolly a stupid question but how many LEDs can an alarm power by tapping off of the original LED. whats the best way to add more LEDs like say 5 or more plus I got the 2 LEDs that go into the headlights so keep in mind thats all gonna meet up too. Thanks for your input!
Mike M2
Platinum - Posts: 2,652
Posted: January 14, 2009 at 6:09 PM / IP Logged
Most alarms will tell you the most LED's it can handle in the manual. LED's are usually wired in series, not parallel....
Mike M2
Tech Manager
CS Dealer Services
kandyman67
Posted: January 14, 2009 at 7:07 PM / IP Logged
mike this alarm doesnt say the most amount and i dont know what it means when you said LEDs are wired in a series not parallel thanks
Mike M2
Posted: January 15, 2009 at 6:42 AM / IP Logged
Most will hold around 6. Parallel is when all the negatives are ties together and all the positive are tied together. In series, one negative is tied to the next LED positive and done this way thruout all the LED's.
Mike M2
Tech Manager
CS Dealer Services
djspark
Posted: January 27, 2009 at 3:23 PM / IP Logged
can you use a relay and get more power from the battery and have more LEDs ?
91stt
Silver - Posts: 564
Posted: January 27, 2009 at 4:19 PM / IP Logged
The maximum number of LED's you can drive from the alarm will depend upon the transistor used in the unit. It could be one or more. If there is a number on the transistor, you can look up the specs through a quick search or sites like Digi-key . A typical LED draws about 20 mA on average, so you can use that as a reference to determine if you are drawing more current than the transistor is able to supply. I would advise against using a relay to control an LED since it may not switch quick enough to flash the LED reliably.
91stt
Silver - Posts: 564
Posted: January 27, 2009 at 4:23 PM / IP Logged
Another thing with regard to adding a relay. Do you actually want to listen to the constant clicking of the relay?
Posted: January 28, 2009 at 9:32 AM / IP Logged
Also most alarm LED's and Mike M2 could probably correct me here run on 2.5-3volts one Italian alarm even runs the red feed as the neg side so forget relays. I believe DEI once showed a diagramme running 6 or 8  connecting both in seriesd and parallel. Oh why do novices bring in relays as if they were a magic cure all.
Posted: January 28, 2009 at 9:37 AM / IP Logged
Sorry, printing error seriesd should of course have read seiers and the other point is with the high brightness LEDs  1 placed high in the dash (inst cowl pointing out through the front window as an example) is usually more than adequate.
Posted: January 28, 2009 at 9:38 AM / IP Logged
I've lost it!  Meant to write SERIES  wiring leds -- posted image.
