Lanzar 2000W amp opinions
dragonrage
Copper - Posts: 193
Posted: March 18, 2003 at 10:16 AM / IP Logged
Anyone know if this amp is decent? http://www.lanzar.com/itempage.asp?model=D2000M
I don't expect it to be great but I don't have a lot of money and I can't afford to spend $400-$500 on an amp.
2009 Pontiac G8 in planning stage
HU: ?
Speakers: ?
Amps: ?
dragonrage
Copper - Posts: 193
Posted: March 18, 2003 at 10:23 AM / IP Logged
or maybe this is better? http://www.lanzar.com/itempage.asp?model=VIBE1500D
HU: ?
Speakers: ?
Amps: ?
thepencil
Gold - Posts: 1,526
Posted: March 18, 2003 at 10:52 AM / IP Logged
I found the VIBE 1500D better, looks and performance wise.
Be careful whose advice you buy, but be patient with those who supply it.Lanzar 2000W amp opinions -- posted image.
bberman1
Gold - Posts: 2,314
Posted: March 18, 2003 at 10:56 AM / IP Logged
First off before I make any suggestions what kind of subs will you be running? And 2nd what is your budget?
dragonrage
Copper - Posts: 193
Posted: March 18, 2003 at 10:59 AM / IP Logged
The subs that are in my sig...500W RMS/1000W peak each. And as low as possible :D don't want to go over $250 for the amp. I'd prefer class T over class D, but they aren't out with any respectable power ratings yet so I will have to go with class D. And it should preferrably be 1 ohm stable since I have 2 4ohm DVC subs, either that or it should have a really high power rating to compensate for the load being halved (I can run in 1 ohm or 4 ohm, 1 might overload, 4 will be a waste)
HU: ?
Speakers: ?
Amps: ?
Big Purds
Silver - Posts: 574
Posted: March 18, 2003 at 11:19 AM / IP Logged
a JBL bp1200.1 is about $280, I dont know if you can go that far over your budget, but it does the same power into 2 and 1 ohm...and they are probably one of the best amps you can find as far as bang for buck goes...
dragonrage
Copper - Posts: 193
Posted: March 18, 2003 at 11:20 AM / IP Logged
JBL BPs are 1-ohm stable? I was actually looking at them.
HU: ?
Speakers: ?
Amps: ?
Big Purds
Silver - Posts: 574
Posted: March 18, 2003 at 11:31 AM / IP Logged
the powervalve amps are...
like I said, they do the same power at 2 and 1 ohm...
dragonrage
Copper - Posts: 193
Posted: March 18, 2003 at 12:09 PM / IP Logged
Ok, it's a consideration then. But I'd still like some feedback on the 2 Lanzars above.
HU: ?
Speakers: ?
Amps: ?
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
