eclipse hu problem
nemizis
Posted: January 21, 2009 at 5:15 PM / IP Logged
Ok, I have a Eclipse cd8443, and when I bought it the guy had it running and playing a cd. So I would know that it was working. So now I installed it in my car, everything thing seems to work fine, but when I put a cd in it reads it and you can see it counting the seconds on the song etc. But it makes no sound?.. If I pop out the cd then the radio comes on and it works fine through all my speakers and subs. I am running all my speakers from an external amplifer. Any help would be awesome!! I am hoping that there is just some setting, I need to change or something.. I haven't had an Eclipse HU before now.....
DYohn
Platinum - Posts: 10,741
Posted: January 21, 2009 at 5:54 PM / IP Logged
Did you use the power antenna lead as your amplifier remote wire?
nemizis
Posted: January 21, 2009 at 6:00 PM / IP Logged
Well, that is a very good question. Obviously If I did, I didn't mean to use the power antenna as the remote.
But it does sound like a very good possibility, I'll check it out and post back. ASAP
joch1314
Copper - Posts: 301
Posted: January 21, 2009 at 7:01 PM / IP Logged
My money's on the power antenna hooked up and not the remote wire!
...half of the truth can be worse than a lie. <----Roger Russell said that..
nemizis
Posted: January 21, 2009 at 7:36 PM / IP Logged
Yep , that was the problem!!!
Sometimes you just need a different point of view!!!
Thanks guys!!
Thursday, February 19, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
