boston acoustics gtr10 passive radiator
rubicrawler_lj
Member - Posts: 17
Posted: January 23, 2009 at 4:25 PM / IP Logged
I have been unable to get a response from Boston Acoustics on how to compute an enclosure's size when using their passive radiator.
Can one of you audiophile's help me out?
haemphyst
Platinum - Posts: 5,059
Posted: January 23, 2009 at 7:40 PM / IP Logged
What woofer will you be pairing it with? I need T/S parameters, and I can probably get you a starting point.
SPL or SQ? Also, have you ALL the weights that came with it?
rubicrawler_lj
Member - Posts: 17
Posted: January 23, 2009 at 9:25 PM / IP Logged
First of all, thanks for offering to help.
I am in the design stages still, looking for sound quality not SPL. I will probably be going with MB Quart's Discus series10" subwoofer, model # DWI-252 with DVC @ 2 ohms, 300 watts RMS continous.
http://www.mbquartusa.com/discus_subs_parameters.html#
Specs: Vas= 38 liters, Fs= 32 hertz, Xmax= 5mm, Qts= 0.322
rubicrawler_lj
Member - Posts: 17
Posted: January 24, 2009 at 8:24 AM / IP Logged
Sorry, I forgot to list the following specs:
Qes= 0.344, PeRMS= 300 watts and PeMax= 600 watts
Additional information, recommended sub enclosures for the DWI-252 posted at MB Quart website.
http://www.mbquartusa.com/discus_subs_enclosures.html
When I input all the parameters including the GTR10's 9.09" diameter into AJ Design Software's Subwoofer Box Enclosure Design Calculator, I get a port length of over 272".  boston acoustics gtr10 passive radiator -- posted image.
http://www.ajdesigner.com/fl_subwoofer/subwoofer.php
jmelton86
Gold - Posts: 1,228
Posted: January 29, 2009 at 6:34 PM / IP Logged
haemphyst, do you remember trying to model something up with the one I have?
You weren't able to because BA doesn't list the appropriate t/s perimeters for the PR... or something.
2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
rubicrawler_lj
Member - Posts: 17
Posted: January 29, 2009 at 9:02 PM / IP Logged
I was told by a local car audio shop that I should design the enclosure to the subs sealed enclosure specs and account for the PR's volume.
Does this make sense?
rubicrawler_lj
Member - Posts: 17
Posted: February 01, 2009 at 9:20 AM / IP Logged
UPDATE:
Received an email from Boston Acoustics that stated that I should use the sealed enclosure interior volume recommendations for the subwoofer that I am pairing it with as a guideline.
They also informed that their PRs where designed specifically to be paired with their G5 subwoofer series so I am on my own.
haemphyst
Posted: February 01, 2009 at 10:37 AM / IP Logged
I'm glad you brought this one back up... I DID actually plug all the numbers I had for these components into my JBL, but I was unable to come up with anything decent. HUGE enclosures with reasonable extension or "whumpy" tiny enclosures for output's sake.
I'll try to get a couple screenshots and upload 'em for you.
rubicrawler_lj
Member - Posts: 17
Posted: February 01, 2009 at 11:50 PM / IP Logged
The link that Boston Acoustic pointed me to recommends that I set the GTR10 to "tunning mode 3" for a resonant freq of 30Hz in a 0.5 cu ft enclosure. However, BA says these figures are only applicable when used with their G5 series subwoofers.
http://mobile.bostonacoustics.com/manuals/G5_GTR_Man.pdf
Additional information:
Looks like the overall size for my underseat enclosure is going to be 12"X30"X6", I might be able to bump it out another 1.25" to ?" in the center section of the seat (9"X28"X?).  Without any "bumping out",  I should wind up with a Vbox of 0.78 cu ft using 3/4" mdf.
Should I shelve the PR idea all together and go exchange my 10" sub for two 8" subs instead? I might be able to get a hold of two JBL GTO 804's pretty cheap, would they do the trick?
