ok...we're talking about the VAlet Deluxe Remote Start and Keyless entry right? I hope so cause thats the only thing I can think of that is 552T...if not, than I'm about to ramble about nothing remotley similar.
First off...here's a quick wiring diagram..
12volts red & pink/black + ignition harness
Starter yellow + ignition harness
Ignition RED / blue + ignition harness
Power Lock pink/purple - back of fusebox
Power Unlock same wire as power lock
Lock Motor ORANGE / black 5wi back of fusebox
Unlock Motor pink/black 5wi back of fusebox
Disarm Defeat ORANGE / purple 5wi back of fusebox
Parking Lights+ DO NOT USE
Parking Lights- lt. GREEN/ orange - headlight switch
Hazards
Turn Signal(L)
Turn Signal(R)
Door Trigger - right of st column, blue plug
Dome Supervision use door trigger
Trunk/Hatch Pin tan/black - conn. 1, pin 7 @ BCM
Hood Pin BROWN / tan - conn. 1, pin 6 @ BCM
Trunk/Hatch Release ORANGE / pink - conn. 1, pin 17 @ BCM
Power Sliding Door N/A
Factory Alarm Arm
Factory Alarm Disarm lt. GREEN/ orange - conn. 2, pin 9 @ BCM
Disarm No Unlock see factory alarm disarm
Tachometer NOT grn/org or org/grn ac ign coil, coil pack, or injector
Horn Trigger BLACK/ red - steering column
Memory Seat 1
Memory Seat 2
Memory Seat 3
Immobilizer By Pass : Not Available
MAKE : JEEP | MODEL : LIBERTY | YEAR : 2003
* The logo is registered trade mark of Jeep Corporate.
OK...now it says you MUST USE RELAYS. Also, as you can see by the diagram..Lock and unlock go through the same wire. Lock is a negative Trigger which must go through a 1.4K Ohm Resistor, and unlock is a negative trigger through a 426 Ohm Resistor. THIS IS SAID BY DEI...so you can't use just the onboard relays...
Ok I'll take a stab at the relay set-up....but I ain't no relay genius, so I am probably wrong, so clarify this with someone...and if I am wrong...don't jump all over me about it...
take two relays.
relay 1) 85= 12V, 86= negative ( use unlock from the alarm which would be the blue wire on the doorlock harness ) 30= ground, 87=not used, 87a wire out with a 426 Ohm resistor. This is the UNLOCK RELAY.
the Lock relay is the same except 86 will be the Green wire on the harness. and you'll use a 1.4K ohm resistor. This is the lock relay...
I hope that does it...and if no one comments on the reply, Check with a local shops installer, to confirm the relay set-up...Hope I helped...
