2008 iveco daily cdl location
auido_dyl
Posted: January 29, 2009 at 12:24 PM / IP Logged
Is the CDL unit part of the BCU? Is it on CANBus? Where on earth is it?
Need to fit a sigma tommorow.
Thanks guy's!
Dyl
Posted: January 29, 2009 at 3:32 PM / IP Logged
Neither you, me Cobra or the dealers seem to know;  it's either in fuse box or under hood! This is what I did on the last one:- Pick up EVERY pair of motor wires, ie 2 in front, one at headlining and one in nearside loom under vehicle (honestly), and shove a small relay into every location!!! What a mustard. Don't even give ask me for colour codes, it's French style (Italian company probably made in Spain) wiring i.e. all pastel colours and changing every month. Give me a Sprinter any day. If you get a result, please tell. You might be right about the CAN, mine was an 03, no CAN
auido_dyl
Posted: January 30, 2009 at 4:06 AM / IP Logged
07 onwards run on a half CAN system. Ignition, lighting and radio are on CAN. Security are NON-CANBus Got some info here.
Will confirm colours later on.
Iveco Daily 2007--- Alarm Data
+12V Supply:
        PLEASE TEST AT FUSE BOX IN A WHITE M/PLUG
Ignition Supply:
        PLEASE TEST AS FUSE BOX IN A WHITE M/PLUG
Ground:
        AT OE GROUND POINT
        AT AN ALTERNATIVE GROUND POINT
Hazards:
        AT THE REAR OF THE HAZARD SWITCH - AWAITING ON WIRING COLOURS
Bonnet:
Doors:
        AWAITING ON FURTHER INFORMATION
Boot/Hatch:
Immobiliser - Starter:
        HEAVY WHITE WIRE AT FUSE BOX - PLEASE TEST!
Immobiliser - Fuel:
Lock Wire:
        CDL WIRE "8906" IN THE VERY CENTRE OF THE DASHBOARD - PLEASE CONFIGURE THE CDL WIRING FOR "DIRECT MOTOR CDL" - AWAITING ON WIRING COLOUR * SEE NOTES
Unlock Wire:
        CDL WIRE "8901" IN THE VERY CENTRE OF THE DASHBOARD - PLEASE CONFIGURE THE CDL WIRING FOR "DIRECT MOTOR CDL" - AWAITING ON WIRE COLOUR * SEE NOTES
CDL Notes:
        * ALSO PLEASE INSULATE THE RELAY SIDE OF THE CUT ON BOTH OF THESE WIRES. ** AN ADDITIONAL CDL WIRE "8902" IN THE VERY CENTRE OF THE DASHBOARD - AWAITING ON WIRE COLOUR & POLARITY.
