relay enclosure
johnson73801
Member - Posts: 42
Posted: January 29, 2009 at 2:00 PM / IP Logged
im doing a major upgrade on my car and need to add in alot of relays,does anyone know where i can find a relay box that houses multiple relays?
johnson73801
Member - Posts: 42
Posted: January 29, 2009 at 2:02 PM / IP Logged
 im working on a 79 camaro with a 5.7ls1, addin relays for lights fuel pump fans ignition  coils and a few other parts.
KPierson
Platinum - Posts: 3,527
Posted: January 29, 2009 at 3:56 PM / IP Logged
What I typically do is find relay harnesses that connect together (like the ones at www.delcity.net).
You can connect all the relays in a row and then screw them down to the firewall or some other out of the way place.
I don't know of any premade boxes though.
Kevin Pierson
hotwaterwizard
Silver - Posts: 1,350
Posted: February 01, 2009 at 1:11 PM / IP Logged
Any Idea how many relays?
I would go to Pick and Pull and see what I could Find.
John DeRosa (Hotwaterwizard)
Stockton California
When in doubt, try it out !
johnson73801
Member - Posts: 42
Posted: February 01, 2009 at 2:42 PM / IP Logged
it will be around 8-10 relays added.
hotwaterwizard
Posted: February 02, 2009 at 12:55 AM / IP Logged
ISO Relay Socket
Wiring socket for use with standard ISO-type automotive relays.
Color-coded wires come pre-attached for ease of installation.
Can be joined together to make installation of multiple relays a snap (see photo).
relay enclosure - Last Post -- posted image.
http://www.injector.com/electricalcomponents.php
Stockton California
hotwaterwizard
KPierson
Posted: February 02, 2009 at 5:22 AM / IP Logged
hotwaterwizard wrote:
ISO Relay Socket
Those look like the same harnesses that www.delcity.net has, but Delcity has them for $1.50 a piece!
http://www.delcity.net/store/search/p_72562.h_72661.a_1.t_1.n_y
Kevin Pierson
hotwaterwizard
Posted: February 03, 2009 at 12:07 AM / IP Logged
I just used their product for referance Cheeper is better, The Idea is Free though. relay enclosure - Last Post -- posted image.
Here they are for $1.65 each only 4 wires though relay enclosure - Last Post -- posted image.
http://www.allelectronics.com/make-a-store/item/SRLY-12/AUTO-RELAY-SOCKET-4-WIRE/1.html
Here is the 5 wire version for $2.00 each relay enclosure - Last Post -- posted image.
http://www.allelectronics.com/make-a-store/item/SRLY-2/SOCKET-FOR-AUTOMOTIVE-RELAY/-/1.html
Stockton California
Posted: February 10, 2009 at 7:09 PM / IP Logged
Of course you could always go to a vehicle breakers and look for Cherokees, they had a lovely longitudinal relay/fuse box for the engine bay and a square one inside.
Saturday, May 11, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
