Wiring help..96 civic hatch
igone
Posted: March 19, 2003 at 3:21 PM / IP Logged
Hi everyone,
I just bot a hornet car alarm and want to install it in my 1996 honda civic dx.  I wanted to know if anyone has had any experience with the Hornet model 725T alarm.   Does anyone have any wiring instructions they can give me?  I'm a novice at this..and any help would be greatly appreciated..  Thanks
RaveChild
Copper - Posts: 54
Posted: March 19, 2003 at 5:32 PM / IP Logged
Here are the wires for your car:
|              12V|white               |+  |ignition harness            |
|          STARTER|BLACK/ white         |+  |ignition harness            |
|         IGNITION|BLACK / YELLOW        |+  |ignition harness            |
|  SECOND IGNITION|yellow              |+  |ignition harness            |
|        ACCESSORY|WHITE/ black         |+  |ignition harness            |
| PARKING LIGHTS +|RED / black           |   |dkp or fuse box or *2       |
| PARKING LIGHTS -|                    |   |                            |
|       HEADLIGHTS|RED / wht(L)RED / blu(H)|+  |column or fuse box          |
|     DOOR TRIGGER|GREEN/ black         |-  |drivers 'A' pillar          |
|  TRUNK/HATCH PIN|blue/black          |-  |dkp or fuse box*3           |
|         HOOD PIN|                    |   |                            |
|TRNK/HTCH RELEASE|                    |   |                            |
|  FCTRY ALARM ARM|                    |   |                            |
|FCTRY ALRM DISARM|                    |   |                            |
|       TACHOMETER|blue                |   |test connector*1            |
|       BRAKE WIRE|GREEN / WHITE         |+  |brake switch                |
|     HORN TRIGGER|gray or blue        |-  |steering column             |
|           WIPERS|blue and blue / YELLOW|-  |column                      |
|  LF WINDOW UP/DN|                    |   |                            |
|  RF WINDOW UP/DN|                    |   |                            |
|  LR WINDOW UP/DN|                    |   |                            |
|  RR WINDOW UP/DN|                    |   |                            |
Notes:
*1 Drivers side fire wall.  *2 Male blade connector at fuse box.  *3 Two door hatch back does not have trunk pin.
Moderator - Posts: 12,488
Posted: March 19, 2003 at 7:12 PM / IP Logged
http://www.directed.com/guides/manuals/ig/hornet/N725T_4-02.pdf
Monday, December 22, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
