alarm, 2001 mustang
k9decal
Posted: February 05, 2009 at 9:38 PM / IP Logged
I just got a new car, Mustang 2001 v6 3.8
The factory alarm that came with it is working fine, for example it can open and lock my doors but the thing that is wrong with it is that when I activate it the alarm would not go off. Like when I activate it when im inside my car then I wait a couple of minutes then open the door form the inside it does nothing the alarm does not even go off.
Any help or tips I can use to fix it
ckeeler
Gold - Posts: 1,461
Posted: February 05, 2009 at 10:09 PM / IP Logged
you dont have an alarm. you most likely just have a keyless entry.
k9decal
Posted: February 05, 2009 at 11:28 PM / IP Logged
maybe but why does it beep or has a option for panic on my remote
JWorm
Platinum - Posts: 2,208
Posted: February 05, 2009 at 11:37 PM / IP Logged
Panic and an alarm are two different things.
Chris Luongo
Platinum - Posts: 3,746
Posted: February 06, 2009 at 7:05 AM / IP Logged
Yes, the factory usually just gives you a full-featured keyless entry...........that is, it's got panic, it's got horn-honk with second lock, and it turns on the domelight when you unlock.
Those are all features you'd often pay extra for when buying an aftermarket keyless entry.
But still, they didn't give you an alarm.
So basically, you have a full-featured keyless, but that's it.
If you want an alarm, but you like the factory remotes, they make alarms that can use the original remote.......Audiovox PRO-9233, or DEI's Automate AM1 are two examples.
