amp won't come out of protect mode.
k.gren
Member - Posts: 31
Posted: February 10, 2009 at 10:16 AM / IP Logged
Hey i'm new here. I am pretty knowledgeable with car audio/video, but this one has boggled my mind. I am running two 12" Kicker Comps on a Hifonics BXi608 amp. I have had this setup for awhile now but the other day it went into protect mode and I can't get it out. I have removed the in-line fuse for a day to try and reset the amp, that didn't work. I checked all of my wiring and everthing is fine with that. Can anyone tell me what is wrong?
~K.Gren~
soundnsecurity
Gold - Posts: 2,720
Posted: February 10, 2009 at 12:04 PM / IP Logged
Hifonics amp went bad, maybe? probably. is it still in protect with the subs unhooked?
Platinum - Posts: 13,725
Posted: February 10, 2009 at 7:27 PM / IP Logged
Chances are your amp has one or more shorted output transistors.  You will need to have all outputs on the side that has the shorted ones.
k.gren
Member - Posts: 31
Posted: February 11, 2009 at 12:03 AM / IP Logged
I have no idea what it was but I took out my inline fuse again during class today and when I came back from class and put the fuse back in they worked fine and have since then. Thanks for the help though!
~K.Gren~
soundnsecurity
Gold - Posts: 2,720
Posted: February 11, 2009 at 10:07 AM / IP Logged
its a miracle
k.gren
Member - Posts: 31
Posted: February 13, 2009 at 12:42 AM / IP Logged
I thought I had it fixed.. it did it again today.. It's like an off and on thing.. sometimes when i start my car they work, other times they dont... i just put a new battery in and tested me alternator.. I have no idea what it could be..
~K.Gren~
Posted: February 13, 2009 at 2:19 AM / IP Logged
Disconnect the speakers and the RCA cables from the amp.  Using a volt meter verify you have a good power, ground and remote connections on the amp.  If the voltage is good and the protect light is still coming on, your amp is broken.  With it's intermittent nature, you may have broken legs on the output transistors of the amp.  This is a common problem with those amps if they are mounted to a sub enclosure.
6thaveme
Copper - Posts: 74
Posted: February 13, 2009 at 11:43 AM / IP Logged
hifonics amps are notories for doing that there doller to watt ratio is unbeatable but with reliabilty you cant count on them..kinetic batteries help the life of these amps...
4 12s cvr sealed
2 hifonics bxi608d
1 kinetic hc 800
alpine reciever
infinity kappa door speakers
j.reed
Copper - Posts: 716
Posted: February 13, 2009 at 12:25 PM / IP Logged
How is simply adding a "kinetic" battry going to make the life of that amp longer? Keeping you voltage up to keep it within it operating limits yes. But simply just adding a batt to a sub par electrical system is just asking for yet one more problem.
amp won't come out of protect mode. -- posted image.
Posted: February 13, 2009 at 6:03 PM / IP Logged
That is really a no brainer.  The HiFonics rep also reps Kinetic batteries.
Friday, February 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
