two 2007 kicker l7's 12 what amp?
havoc_hack
Posted: February 11, 2009 at 12:38 PM / IP Logged
what model, size, watt, amp would i need for two kicker L7's
j.reed
Copper - Posts: 716
Posted: February 11, 2009 at 1:37 PM / IP Logged
they will handle 1500RMS, but to help you with an amp we need to know if they are dual 2ohm or 4ohm
two 2007 kicker l7's 12 what amp? -- posted image.
soundnsecurity
Gold - Posts: 2,720
Posted: February 11, 2009 at 2:06 PM / IP Logged
if they are the dual 4 ohm model then you need to get an amp that will make between 1500 and 2000W at 1 ohm.
if they are dual 2 ohm you need to get an amp that will give you that power at 2 ohms.
it would help if you told us your budget on amps so we are not just taking shots in the dark.
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
