1987 buick grand national audio
jim87gng
Posted: February 17, 2009 at 5:08 PM / IP Logged
First time poster, so please be patient.
I have the following audio equipment to be installed, and I have little experience.
Alpine CDP 9855,   Alpine pa-1(EQ)
Polk Audio component speakers (1' and 5.25")
factory 4 x 10 (rear deck) JBL GT)1412 sub, Fosgate 500.2 amp.
What size and what type sub box?  replace factory speaker wiring? wiring diagram? additional amp required?wire sizes?fuses? dampening?
Thanks to any and all replies
Jim
jim87gng
Posted: February 18, 2009 at 2:02 PM / IP Logged
No response to my first post:
Jim
If there is some one local who can help me with this, i would appreciate hearing from them.
thanks
Jim
forbidden
Platinum - Posts: 5,354
Posted: February 19, 2009 at 2:31 PM / IP Logged
Ideally, add an amplifier for the front speakers or use the amp you have now for the front and a new amp for the sub. If you plan on adding rear speakers then consider a 4 channel amplifier to power the front and rears. If you are going to go ahead with rear speakers, you can purchase a 4x10" - 6x9" adaptor template from most specialty car audio shops or drop in a replacement 4x10", the Eclipse SE8405 is a fine speaker for this.
1)  Do you think that you need the EQ?
2) Definitely run new wiring, the wiring will be determined by the size of the amps and the length of the wire.
3) Sound deadening is a plus, although this car is heavier metal than most of the coke cans on wheels that are produced these days.
4) If you are after some bass and a easy build, a sealed box of about 1.25 - 1.75 cubix foot is more than ample. If you are trying to get loud, then a properly designed and constructed ported box is the way to go.
jim87gng
Posted: February 19, 2009 at 9:12 PM / IP Logged
Thanks Rob,
I will look at those Eclipse units.
1. it was included in the package, and it fits in the opening nicely.
   Will using it provide any benefits? or negatives?
2. will do, what is normally used for electrical protection?
3. where in the car would this benefit most?
4. I plan to put the box on the shelf.In which direction should the speaker face?
Your helpful replies are appreciated.
thanks
Jim
moparfan1234
Copper - Posts: 59
Posted: February 19, 2009 at 10:07 PM / IP Logged
jim87gng wrote:
Thanks Rob,
thanks
Jim
1. i have never used a 2nd EQ i feel its not really needed.
2. the power wire to your amp should have a fuse close to the battery
3. mostly where it rattles but if you want to go all out put it every where truck lid floors etc.
4. what kinda of car is this? regular car with trunk? if so the sub goes in the trunk facing to the back of the car
87 ramcharger eclipse CD5000 2 15" memphis M3 kenwood 900rms mono amps
99 dodge cummins diesel eclipse CD4000 1 12" memphis Mclass 800rms audiobuhn amp
jim87gng
Posted: February 20, 2009 at 12:12 PM / IP Logged
thanks,
Yes, regular car (87Buick Regal)
so the sub should face the back bumper?
hmm...ok
Jim
loosingmymind
Copper - Posts: 103
Posted: February 20, 2009 at 6:41 PM / IP Logged
I wouldnt use an external EQ. Let your headunit do that. I have an 85' GN,  and the car is acoustically sound! Sometimes simple is better.  I would recomend a 5-channel amp for your application. Less strain on the vehicle and it's charging system.  And your turbo needs that.  I would check out a 5-channel from US Amps. They have a great XT series 5-channel.
Dave
David Fancher
USACi World Finals 2006
4th Place SQ PRO 601+
Saturday, April 25, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
