07 dodge ram hid
mobgb
Posted: March 05, 2009 at 8:21 PM / IP Logged
I've installed the Notto Se HID kit on my truck. When the car is off the lights work great. When I turn the truck on the lights flicker then go off. It is hooked up correctly and came with a very nice relay and wiring harness. I've read and tried everything and nothings seems to work. If you own a Ram and have delt with this would really apprieciate your help.
mobgb
Posted: April 17, 2009 at 6:46 PM / IP Logged
Anybody have any clues yet?
diffduck
Posted: May 03, 2009 at 9:19 AM / IP Logged
have you figured it out yet?... i just installed HID high/low kit myself and the supplier has no clue what the issue is and ive spent 2 days on line trying to figure it out. i think it has something to do with the negative pulse to check for a burnt out bulb. mine works great when engine off... changes from high to low no issues. but i start the truck up and it flashes from high to low beam a few times and either stops  or burns out the fuse. i am a mechanic so i know the power supply and grounds are good. im gettin gready to tear the whole deal out and buy the fake bulbs .
new hemi owner
Tripnbeats
Member - Posts: 12
Posted: May 28, 2009 at 9:32 PM / IP Logged
https://www.the12volt.com/installbay/forum_posts.asp~TID~107296~get~last
i posted the reply there and if it doesnt work contact me at STAYNLEVEL@GMAIL.COM
Monday, May 20, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
