samsung rv stereo
odd job al
Posted: March 16, 2009 at 6:51 PM / IP Logged
I recently purchased a used Alfa Gole 5th wheel. Installed in it is a Samsung Max-932 Audio system. It seems like a nice system except for the CD. The 3 disk table will not eject and makes noise like it is trying but winds up with an error on the display. Does anyone have an idea on how to fix or info on how to fix or find a replacement unit. I can not seem to find one.
oddjobal.com
Platinum - Posts: 13,726
Posted: March 16, 2009 at 7:30 PM / IP Logged
What are the chances the unit was transported with discs inside?  A disc could have gotten shuffled out of it's place and is now bound up in the drawer.
odd job al
Posted: March 16, 2009 at 8:05 PM / IP Logged
It is possible. When I press disk  1,2,or 3.  I can not hear the turntable move. I can not find a release lock hole and do not want to snap anything trying to open it. It will not eject. I could give it a swift kick :>)
Posted: March 16, 2009 at 8:19 PM / IP Logged
You will probably need to remove the audio system from the cubby hole that it resides in and remove the cover.  If the CD mechanism is at the top of the unit, it should be pretty easy to remove them.
odd job al
Posted: March 16, 2009 at 8:44 PM / IP Logged
I tried using a thin blade knife (12") inserted above the CD drawer. I gentley went from side to side and did not feel a jamed CD. Sounds like I have to pull the unit. It was worth a try. thanks for the Idea.
Saturday, May 9, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
