vss, 2009 trailblazer
cisanta
Posted: March 25, 2009 at 9:39 PM / IP Logged
Hi Im need some help finding the location and wire colors for the VSS and brake wire for a 2009 trailblazer. In regard to brake wire there is a plug w/ about 6-7 wires on top of the brake pedal but don't know for sure which is the brake wire.
cisanta
Platinum - Posts: 13,725
Posted: March 26, 2009 at 5:10 AM / IP Logged
     Battery          RED          (+)          IGNITION SWITCH HARNESS
     Ignition 1          PINK          (+)          IGNITION SWITCH HARNESS
     Ignition 2          WHITE          (+)          IGNITION SWITCH HARNESS
     Accessory 1          ORANGE          (+)          IGNITION SWITCH HARNESS
     Accessory 2          BROWN          (+)          IGNITION SWITCH HARNESS
     Starter 1          YELLOW          (+)          IGNITION SWITCH HARNESS
     Anti-Theft Type          GM PASSLOCK II® ANTI-THEFT SYSTEM
     Anti-Theft Descript          THE BCM MODULE MUST SEE A SPECIFIC RESISTANCE VALUE BEFORE THE VEHICLE WILL START PROPERLY
     Key Sense          LIGHT GREEN          (-)          IGNITION SWITCH HARNESS
     Tachometer          WHITE          (AC)          AT PCM MODULE ON DRIVER SIDE OF ENGINE
     Speed Sense          DARK GREEN / WHITE          (AC)          AT PCM MODULE ON DRIVER SIDE OF ENGINE
     Parking Lights          BROWN          (+)          AT VEHICLE FUSEBOX UNDER REAR LEFT SEAT
     Low Crr. Pk Lights          GRAY/BLACK          (-)          AT VEHICLE LIGHT SWITCH HARNESS
     Brake Lights          WHITE          (+)          AT SWITCH ABOVE BRAKE PEDAL
     Reverse Lights          LIGHT GREEN          (+)          AT VEHICLE REAR FUSE BOX UNDER REAR LEFT SEAT
     Horn          BLACK / YELLOW          (-)          IN HARNESS AT STEERING COLUMN
     Rear Defrost          VIOLET
Friday, March 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
