caps draw from battery when car is off?
nyguy4u
Copper - Posts: 148
Posted: March 27, 2009 at 1:27 PM / IP Logged
Hi guys,
I have a bit of a problem.
My system consists of (3) 15" JL subs, (3) 1,000 Kenwood amps, (1) JL Audio 500 watt amp, line driver, cross over, and (2) 1 Farad caps.
My car for some reason is always dead if sitting for a week without use. I disconnected my Viper alarm completely to see if the drain was from that - and I had the same problem - so my alarm as a culprit is out.
I bought an Optima Battery Yellow Top, same problem. Got a Red Top - still the same problem. Any battery put in my car drains.
Installed a high output alternator - and while my lights don't dim, and everything runs great when everything is powered on - the battery is still completely dead if sitting for a few days.
My local audio shop swears up and down it's because of my 2 caps. They said being I did the big 3 upgrade and purchased a high output alternator, that the caps simply are not needed. After he told me that, I did a google search, and from what I can read, caps don't drain the battery when the car is off. The manager at the shop says it's the caps and they aren't needed, a google search stated the complete opposite.
So, now I'm coming on here to hopefully get the right response. Should I ditch the caps? And is that the culprit draining any battery that is dropped in my car?
Thanks in advance
djrankin004
Copper - Posts: 154
Posted: March 27, 2009 at 3:17 PM / IP Logged
my voltage reader on my tsunami still shows readout when i turn off the cars. Even an hour later when i hit the door locks it shows over 12 vlts. But i figured that was just stored power and not power still being drawn from the batttery
mrarff
Copper - Posts: 71
Posted: March 27, 2009 at 3:21 PM / IP Logged
I don't know about draining the battery, but capacitors are NOT needed at any time, for any reason. They are made to be sold as a "wonder cure-all" for electrical problems. They are peddled buy greedy sales people. If youv'e done the upgrades, and have a hi-output alternator, then you have SOMETHING somewhere that is staying "on" when it should be off. To me, the only thing you can do is to take the car to a relialbe AUTOMOTIVE electrical specialist. They have tools to trace down the culprit, and can do it for far less than swapping out parts in an effort to find the "rat" in the system. Good luck.
"That'll get ya 10 in Leavenworth,11 in Twelveworth, or 5 & 10 in Woolworth". Groucho Marx
whiterob
Copper - Posts: 351
Posted: March 27, 2009 at 3:44 PM / IP Logged
The caps should not be draining your batteries at all.
Why don't you just disconnect the caps to see if it helps. You don't need the caps at all so it won't hurt to disconnect them to see if that actually helps. If working properly the caps should not be killing your battery but something may be malfuctioning.
Do the batteries only die after they are sitting for a couple of days? If you were to drive around for a while and then turn off the car will it start up fine?
One other thing you could try is to take out the fuse to your audio system when your car sits for a couple of days. If your battery dies still then you would know it wasn't your audio system draining your battery.
Platinum - Posts: 13,726
Posted: March 27, 2009 at 4:40 PM / IP Logged
Do you have an alarm system with starter kill?
nyguy4u
Copper - Posts: 148
Posted: March 28, 2009 at 9:03 AM / IP Logged
My Viper does have a starter kill. But as I've said, I completely pulled the power from the alarm, and it still was an issue.
Whiterob, If my car is running, and I go to start it the same day, or even a day or two after - it's fine. It's when I don't drive it for a week, it just doesn't start. I guess I can take the fuse for the audio system out, but even doing that - being the caps store energy - would it even do anything?
Really, this issue only started after finishing my system - so it has to be related to the stereo - of course I just assumed it was the caps.
bigjohnny
Copper - Posts: 293
Posted: March 28, 2009 at 9:35 AM / IP Logged
so get rid of the caps, you have a HO alt, and done the big 3, you don't need the caps. not to mention 2 farads is pretty low, and probably doesn't provide enough power for even a moderate bass burst.
nyguy4u
Copper - Posts: 148
Posted: March 28, 2009 at 9:41 AM / IP Logged
Well, the caps did help before I had my HO Alternator. Nothing was dimming, etc.
But honestly, if it's not going to help my issue - i'd just keep them in there.
KPierson
Platinum - Posts: 3,527
Posted: March 28, 2009 at 2:46 PM / IP Logged
Wire a current meter in series with the ground wire on your battery and wait 5 minutes and observe the current draw of the system.  Anything over 50mA typically points to something wrong.
The problems with capacitors is when they start to fail they will have excessive leakage current.  Because capacitors try to equalize their voltgae with the system voltage execessive leakage current will kill your battery.
However, the thing to realize here is that caps are in EVERY electronic thing in the car - not just your audio system.  Typically, though, aftermarket equipment is built using inferior components to OEM electronics, so its always a good idea to start eliminating aftermarket stuff first.
Once the current meter is installed I would disconnect the caps.  If there is no change in current then disconnect the amps one at a time, observing the current after each disconnect.  If you get to the end of all your audio equipment and there is still excessive current draw then start pulling fuses.  I would start with fuses for the audio system and the dome light, and then start pulling fuses for other electronic components, again checking the current draw after each fuse is pulled.
Depending on the make/model of your car you may have components that "go to sleep".  If this is the case you will need to wait 5 mintues after shutting all the doors before the current will settle and give you an accurate reading.
Kevin Pierson
nyguy4u
Copper - Posts: 148
Posted: March 28, 2009 at 4:01 PM / IP Logged
KPierson.. awesome advice! Thanks so much!
