can this be done? switch/relay
orangesuburban
Member - Posts: 47
Posted: April 02, 2009 at 10:02 PM / IP Logged
ok, so i am working on a switch board for my car and mapped out 12 necessary switches, i would rather not have 12 switches taking up space so i came up with the idea of...
is there a way that i can wire a momentary switch to a 12 position rotary switch? and use it in the manner of turn to pos 1 push momentary and the item turns on ... go around the dial turn everything off... then be able to go back around the dial and turn things off... all while each position on the dial is in no way affected by another. like say i just want to turn on position 2 4 and 6 and then decide i want to turn off 4 but turn on 9....
i have really though this over and it gets more ludicrous the more i think about it, but it would be the perfect solution to my clutter issue!
any advice would be amazing!
thank you!
ckeeler
Gold - Posts: 1,461
Posted: April 03, 2009 at 10:50 AM / IP Logged
the only way i see that senario happening is by using 12 seperate electronic latching relays connected to your rotary switch, ouch, thats gonna cost!
KPierson
Platinum - Posts: 3,527
Posted: April 03, 2009 at 2:02 PM / IP Logged
Using that approach wouldn't be user friendly at all, it would be a pain to turn everything on and off!
Why so many switches?
Kevin Pierson
Ween
Platinum - Posts: 1,368
Posted: April 03, 2009 at 2:04 PM / IP Logged
hi,
how's about two pushbuttons and a rotary switch.   the first button would turn the circuits on, the second would turn them off.  the rotary switch would need to be 2 pole with 12 positions.  then of course 12 dual-coil latching relays.  how much current are you looking to turn on?  you may or may not be able to use the contacts in the latching relays themselves.  you may also want some type of indicators (12 of them) to let you know when a particular circuit is activated.
m
Posted: April 03, 2009 at 2:16 PM / IP Logged
How about a phone style keypad?  Didn't Radioshack use to do them? You will still need 12 relays, some to latch etc, oh forget it, the other wasy would be a custom remote, Xmitter and rerceiver, you'll still need all those relays unless you buy a receiver with onboard configuable relays.
ckeeler
Gold - Posts: 1,461
Posted: April 03, 2009 at 3:00 PM / IP Logged
what kind of project is this anyway? what is it you are trying to do? maybe there is an easier way to accomplish what you want to do that you haven't thought of.
orangesuburban
Member - Posts: 47
Posted: April 03, 2009 at 6:58 PM / IP Logged
all great stuff guys, thanks!
first, i have thought about using an air ride controller but those are momentary control, and i need a constant.
i had also though about 2 switches and one dial, go on with that idea... lol
i love the idea of a phone dial pad also, that would work
as far as indictors i was just going to use an array 3mm LEDs at the top of the center console i am building...
as for what the switches are controlling it is just the various lights on my car. neons, leds, strobes, light bars, KC lights, just looking for a cleaner way of installing all the switches i want to have, without having to put more things on one switch.
dualsport
Silver - Posts: 983
Posted: April 03, 2009 at 10:38 PM / IP Logged
can this be done? switch/relay -- posted image.
$4.95 from allelectronics.com
This keypad has 12 buttons with individual contacts that you can run to a toggle circuit to drive individual relays to turn them on and off each time you press the corresponding button.
Should be fairly straightforward. I assume you don't need any of this stuff to be on when you leave the car, so you can have it all turn off by default when you turn off the ignition without having to press each button.
KPierson
Posted: April 04, 2009 at 8:07 AM / IP Logged
The contacts of that keypad are only rated at 20mA, so you will need either reed relays or transistors on every contact.
Nice find dualsport!
Kevin Pierson
orangesuburban
Member - Posts: 47
Posted: April 04, 2009 at 8:10 PM / IP Logged
wow, that is awesome and i would love to run it! but im sorry, i have no idea what you guys are talking about for my wiring options... would you mind going into more details on how to wire something like this key pad to work? and how to make it run devices rated at 3 - 30amps
thanks guys!!!
Saturday, July 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
