2005 kia rio sedan diagram
JaDeCaMaRoRS
Posted: April 03, 2009 at 6:52 PM / IP Logged
Hello I am looking for a diagram to wire a car alarm into my 2005 Kia Rio sedan. I checked the DB and didn't find anything for my car.
iteetwo
Member - Posts: 27
Posted: April 04, 2009 at 7:53 PM / IP Logged
2005 Kia Rio Last Update: 2/12/2009
Circuit Wire Color Location
Constant 12 volts BLACK/ BLUE IGNITION SWITCH HARNESS
Ignition 12 volts BLUE/RED IGNITION SWITCH HARNESS
Starter BLUE IGNITION SWITCH HARNESS
Dome Light GREEN/ RED HIGH IN DRIVER KICK PANEL
Trunk Pin LT GREEN/ RED HIGH IN DRIVER KICK PANEL
Parking Lamp GREEN/ BLUE (-) HEADLIGHT SWITCH *
Lock RED HIGH IN DRIVER #201
Unlock YELLOW KICK PANEL **
* Alternate: For Postive Parking Light- RED / GREEN (+) Covers Left Side, BLUE/BLACK (+) Covers Right Side. Driver Kick Panel In Rear Body Harness ** At Door Lock Relay s
#201 See Negative Pulse Door Lock Diagram.
CLICK HERE TO SEE AVAILABLE INTERFACE KITS
   Tach Signal BROWN / RED AT ECM OR DIAGNOSTIC PLUG
Ignition #2 BLUE/BLACK IGNITION SWITCH HARNESS
Ignition #3
Accessory RED / BLUE IGNITION SWITCH HARNESS
Neutral Safety
Brake Light RED / BLACK (+) AT SWITCH ABOVE BRAKE PEDAL
Reverse Light BLUE/BLACK (+) DRIVER'S KICK PANEL-REAR BODY HARNESS
Rear Defrost
OEM Hood Pin: LT GREEN/ YELLOW (-) High In Driver Kick Or At OEM Switch E-Brake: BLUE/WHITE Driver Kick In Rear Body Harness
   Window Up -   D\ BLU/YEL P\ WHT/GRN D\ YEL/RED P\ GRN/RED AT MAIN * #211
Window Down - F/ BLU/RED F/ RED / WHT R/ BLU/WHT R/ BLU/BLK SWITCH
Keysense BLUE (+) IGNITION SWITCH HARNESS
Trunk Release
OEM Horn LT.GREEN/ RED (-) STEERING COLUMN HARNESS
Headlights BLUE (-) AT LIGHT SWITCH HARNESS
OEM Alarm Arm OEM REMOTE ONLY
OEM Alarm Disarm OEM REMOTE ONLY
* All Passenger Window Wires In Driver Kick Panel In Door Harness
#211- See Reversal Rest At Ground Type Window Circuit Diagram
   OEM Keyless Module -
Motor Lock BLUE HIGH IN DRIVER KICK AT RELAY *
Motor All Unlock GREEN HIGH IN DRIVER KICK AT RELAY *
Motor Driver Unlock
(disarm defeat)
OEM Lock Relays - HIGH IN DRIVER KICK PANEL
Add On Security Type - TYPE #2 #222
* Reversal Rest At Ground Ciruit
#222- See AL-100/VIP-4000 Type #2 Circuit Diagram
   Left Front Speaker(+) WHITE/ RED AT RADIO HARNESS; Size:
Left Front Speaker(-) WHITE/ GREEN AT RADIO HARNESS; Size:
Right Front Speaker(+) YELLOW/RED AT RADIO HARNESS; Size:
Right Front Speaker(-) YELLOW/BLUE AT RADIO HARNESS; Size:
Left Rear Speaker(+) RED / GREEN AT RADIO HARNESS; Size:
Left Rear Speaker(-) RED / BLACK AT RADIO HARNESS; Size:
Right Rear Speaker(+) GREEN/ RED AT RADIO HARNESS; Size:
Right Rear Speaker(-) GREEN/ YELLOW AT RADIO HARNESS; Size:
TECH NOTES:
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
