kicker l7 15's box
j.reed
Copper - Posts: 716
Posted: April 06, 2009 at 2:20 PM / IP Logged
suzukiracer019 wrote:
ok so it's better to have them seperate than in common chamber?
In most cases yes. Kicker actually recommends it that way as well. I also always try to do it that way. If for some reason one sub blows it will help protect the other by it still being and operating in a correct enclosure. Usually the only way i run more then one in a single chamber is if im dealing with space restraints because the sub will act as if it is in a little bit larger enclosure. Also output and sound quality are generally better in seperate chambers.
kicker l7 15's box - Page 2 -- posted image.
