wiring dvc 4 ohm subs x6
bwhvac065@aol.c
Copper - Posts: 67
Posted: April 06, 2009 at 8:47 PM / IP Logged
ok after looking at the picture i have them wired up exactly like that, The amp is only halp way up. What else can i do any other wiring options? thanks for the picture it helped a tonwiring dvc 4 ohm subs x6 - Page 2 -- posted image.
Blazerspl
6 rockford 12s
5500 watt pa amp
12.0 cubic enclosure
BIG 3
bwhvac065@aol.c
Copper - Posts: 67
Posted: April 06, 2009 at 8:50 PM / IP Logged
or can i cross the coils positve on one to the neg on the other? the wire up like in the picture?
Blazerspl
6 rockford 12s
5500 watt pa amp
BIG 3
Platinum - Posts: 13,726
Posted: April 06, 2009 at 9:07 PM / IP Logged
I am confused.  Do you have it connected as in the picture or not?  The jumper wire on each woofer needs to go from positive of one coil to the negative of the other coil on that same woofer.
bwhvac065@aol.c
Copper - Posts: 67
Posted: April 06, 2009 at 9:08 PM / IP Logged
Well to kinda simplify it i wired them up as if they were in a line pos pos pos pos pos pos to the amp neg neg neg neg neg neg to the amp with the coils pos to the same coils neg all six are alike
Blazerspl
6 rockford 12s
5500 watt pa amp
BIG 3
bwhvac065@aol.c
Copper - Posts: 67
Posted: April 06, 2009 at 9:11 PM / IP Logged
just like the picture but in a continuous line not split down the middle.
Blazerspl
6 rockford 12s
5500 watt pa amp
BIG 3
bwhvac065@aol.c
Copper - Posts: 67
Posted: April 06, 2009 at 9:20 PM / IP Logged
thats a sweet navigator on the picture
Blazerspl
6 rockford 12s
5500 watt pa amp
BIG 3
Posted: April 06, 2009 at 9:26 PM / IP Logged
Which of the following pictures looks more like what you have?   Notice the top picture has 2 jumpers and the bottom picture has only one jumper.
Option 1 (parallel) = 2 ohm load
Voice coils wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono
Option 2 (series) = 8 ohm load
Voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono
bwhvac065@aol.c
Copper - Posts: 67
Posted: April 06, 2009 at 9:32 PM / IP Logged
that would be option #2
Blazerspl
6 rockford 12s
5500 watt pa amp
BIG 3
j.reed
Copper - Posts: 716
Posted: April 06, 2009 at 10:16 PM / IP Logged
bwhvac065@aol.c wrote:
well is it 1.66 or 1.33? cuz on the calculator on this web site it said it was 1.66 ohms. This  works just fine but the amp is only half way up. I was told i need to wire them in paraell to be able to turn the amp up? Dont get me wrong its super loud now but i know the amp has more butt behind it.
Why do you need to turn the amp up? If you have it wired like in the pic, as i said that is the lowest ohm load wiring combo that is safe for the amp. Yes it is a 1.33 ohm load. 8 ohm per sub / 6 woofers = 1.33 . Which will give you the most power possible from your amp to the subs. Dont get hung up on the amp being at half gain. Half position does not mean you are getting half power. Gain is not a volume knob. Check out this topic on setting gain. https://www.the12volt.com/installbay/forum_posts.asp~TID~85479~PN~1
Tuesday, April 28, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
