2005 350z air bag light
jmsounds
Copper - Posts: 99
Posted: April 17, 2009 at 9:30 AM / IP Logged
hello every one  i'm workig on a 2005 nissan 350z i'm doing a alarm remote start i wire every thing correctly but before i try staring the alarm i started the car with the key  but the airbag light keeps flashing i have no idea why is on  i did not unplug any yellow connector  does any one knows how to turn off  please help soon if you have any question please
thanks any help is welcome
t&t tech
Platinum - Posts: 2,622
Posted: April 17, 2009 at 9:41 AM / IP Logged
unplugging connectors while the engine is running may cause this, have you tried a reset, disconnecting battery and let is sit for a couple minutes to see if it clears, if not, maybe someone else might chime in, or a trip to a dealer is in order to reset. try all options first though, triple check your connections and ensure all your plugs are snapped in properly even the ones you didn't remove but you were working around, just a thought.
jmsounds
Copper - Posts: 99
Posted: April 17, 2009 at 10:08 AM / IP Logged
well i did unplug the battery and the conections are good i used a bypass that does all the funtions  the thing is i started the car first before i plug the alarm  and double check all theconectors   i did screw in the horn on the front bumper  but i know there were no wires or anything around that could have been damage i always check twice before i do anythig
mikvot
Gold - Posts: 1,043
Posted: April 17, 2009 at 10:19 AM / IP Logged
I used these directions on a Nissan Frontier a couple of months ago, and it worked like a charm.
If it does reset, and eventually comes back on, then you have an issue somewhere, and it will have to go to the dealer.
Here is how to reset it:
1. Turn the key from off to on.
2. Watch the airbag light closely. It will stay on for a few secs. and then as soon as it blinks off (the start of the flashing), turn the key off instantly.
3. Count to 5 (1 Mississippi, 2 Mississippi . . . .)
4. Repeat steps 1-3 two more times until you have done the cycle three times.
5. Now turn the key on and watch the light. It will start blinking in a different, slower manner. This is diagnostic mode. You can watch this for a little while, no hurry.
6. Now turn the key off again, Count to 5 like in step 3 again, and turn back on. If the procedure worked, the airbag light will not be flashing.
If it does not work the first time, just repeat the steps again.
jmsounds
Copper - Posts: 99
Posted: April 17, 2009 at 10:54 AM / IP Logged
MIKVOT    it work i started the car with the key and alarm many times to see if the lights comes back on it work so far thanks alot hopefully stays like this for good
thank you very much
Posted: April 17, 2009 at 11:00 AM / IP Logged
Mikvot that was an educational post, do you have access to other vehicles or was it a friendly local dealer?
mikvot
Gold - Posts: 1,043
Posted: April 17, 2009 at 12:20 PM / IP Logged
Actually, I just found it on a Nissan forum. When I had to do that Frontier, there was no way I was paying to take it to the dealer. Just googled "how to reset nissan airbag light," and there is all kinds of fun stuff that will come up.
Platinum - Posts: 13,726
Posted: April 17, 2009 at 3:47 PM / IP Logged
Posted: April 17, 2009 at 5:29 PM / IP Logged
What memory Craig? The other night I went around a LOCAL roundabout 3 times before I realised where I was  2005 350z air bag light -- posted image.
mikvot
Gold - Posts: 1,043
Posted: April 17, 2009 at 7:26 PM / IP Logged
Howie...did you end up going back the way you had just come from?
