08 dodge ram security alarm color codes?
jeepsrock
Posted: April 21, 2009 at 11:46 PM / IP Logged
I need the necessary wire color codes & description for an 08 Dodge Ram, to install an alarm ?
Pete
Posted: April 22, 2009 at 2:18 AM / IP Logged
Try the vehicle wiring section above right.
robertsc
Copper - Posts: 337
Posted: April 22, 2009 at 7:37 AM / IP Logged
they should add that to the add line like you can add a emoticon
save typing the same responce over and over again
Posted: April 22, 2009 at 8:55 AM / IP Logged
RobertSCpm me and I'' explain LAM to you.
jeepsrock
Posted: April 22, 2009 at 10:22 AM / IP Logged
My Trucks model and yr isn't located in the vehicles wiring guide, hence why i am posting.
Pete
robertsc
Copper - Posts: 337
Posted: April 22, 2009 at 11:06 AM / IP Logged
probably because there the same as 07
Posted: April 22, 2009 at 11:28 AM / IP Logged
Take the 07 and use it as your crib sheet testing as you go, I did an 04 V8 Ram recently with no problems, used directechs and here for the info, no problems because there must be at least 8 in the UK.
jeepsrock
Posted: April 22, 2009 at 3:28 PM / IP Logged
I just thought someone here might have or have access to the 08 one.
pete
Posted: April 22, 2009 at 4:26 PM / IP Logged
Read my last post, that's why we are pros.
jeepsrock
Posted: April 22, 2009 at 4:36 PM / IP Logged
I will use the 07 information to help & guide me, but my original post was to see if others may already have it. If not, its no big deal.
What does 8 in the UK have to do with this ?
Pete
