hornet 554t remote won't transmit
funyuns
Posted: April 27, 2009 at 4:57 PM / IP Logged
I have a Hornet 554t. I am on my second 2-way remote and now it isn't working. It is a Valet 477t. The remote receives the 2-way transmissions but won't send any signals. If I use my 1-way tx to arm/disarm the 2-way will show the status just fine. When I push buttons on the 2-way tx the lcd shows that it is transmitting, but the truck doesn't respond. I've tried new batteries and reprogramming the tx. It won't reprogram because the tx isn't sending any signal. My original remote did the exact opposite. It would send signal but not receive any 2-way info.
Any ideas?
Mark Mizenko
Copper - Posts: 460
Posted: April 30, 2009 at 11:15 AM / IP Logged
There are two boards inside the transmitter.  There are two connectors on the mother board to plug the daughter onto it.  The connectors have little legs on them soldered onto the mother board, THEY BREAK LOOSE, causing the problem(s) you're having.  If you're careful, you can open it and fix it.
funyuns
Posted: May 01, 2009 at 9:49 AM / IP Logged
Thanks Mark. I did take it apart to make sure the two boards weren't loose. I hadn't thought to check to make sure the solder joints for the plugs was solid. I'll check it out.
Monday, April 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
