2007 escalade factory nav
mjmauto
Member - Posts: 43
Posted: May 18, 2009 at 6:15 PM / IP Logged
I have a customer with the new body style Escalade who had his non nav factory radio replaced with a factory nav unit awhile back. His lease is up and is getting another 07 escalade, he wants me to put the nav in the new escalade and I was just wondering if this is a pretty straight forward swap ? I was just looking for a heads up before it came in. Any help is greatly appreciated.
Mike M2
Platinum - Posts: 2,652
Posted: May 22, 2009 at 6:38 AM / IP Logged
It will be theftlocked. It will work but you will have to take it to a dealer to have them connect a TECH2 to the truck and release the lock. You may also need to add a VSS wire whcih you can get under the drivers dash. Don't forget about the GPS antenna, which will be located under the cowl where the dash meets the windshield, this pops out...
Mike M2
Tech Manager
CS Dealer Services
mjmauto
Member - Posts: 43
Posted: May 22, 2009 at 3:28 PM / IP Logged
Thanks Mike. The install was pretty simple . It did have to go to the dealer to have the theftlock  released, but other than that it was pretty straight forward . Thanks again for the info.
Sunday, April 28, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
