’05 h2 hummer, viper 5901
majestic1
Posted: May 23, 2009 at 9:24 AM / IP Logged
I'm trying to install the Viper 5901 into an 05 H2 Hummer. I'm using bypass module DLPKGM connected to OBDII pin 2. All the alarm functions work fine (via D2D- Doorlocks, Parking Light, etc....)but when I try to remote start the vehicle it attempts to start 3 times, each time it cranks the starter, but won't turn over. If I put the key in and turn it to the second position it will remote start, but as soon as I remove the key it shuts down.
    Any suggestions on this vehicle with this alarm system? Just to verify wiring, what are the connections between the 5901 and the vehicle ignition harness wiring?
Majestic Motorsports
cpalmer
Copper - Posts: 115
Posted: May 23, 2009 at 10:50 AM / IP Logged
It actually sounds like you may be missing an ignition wire. What are you hooked up to for ign 1 and 2.
proximity
Member - Posts: 30
Posted: May 23, 2009 at 12:31 PM / IP Logged
Pink (alarm) to pink (car)
Pink/White (alarm) to white (car)
Make sure both the red and the RED / white wires from the car are connected up to +12v constant.
proximity
Member - Posts: 30
Posted: May 23, 2009 at 12:33 PM / IP Logged
The red + RED / white wires from the alarm, I meant.
Wednesday, November 26, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
