just curious, wait 8 seconds to start?
t&t tech
Platinum - Posts: 2,621
Posted: May 27, 2009 at 4:25 PM / IP Logged
here's how it went, one of our best customers comes in, we installed remote starters in all his personal vehicles, says he wants the remote start portion removed or de-activated an all the cars!
Reason- he says he has been having problems with one of the vans we did a starter in, a toyota rav4, starter was installed about two and a half years before, so he goes by the mechanic, and the guy points out to him, that the remote start could be the nature of his problems, this is the mechanic's reason- he says, the remote start fires up the engine to quickly from ignition to cranking the starter, he states, that at least eight seconds must elapse after the ignition is turned on and then the starter must crank, not having this delay between ignition and starting he says could cause the pcm to fail.
now i've never heard this theory before, and personally it doesn't make much sense to me, because the average human being doesn't wait eight seconds after turning ignition to start, me personally when i start a vehicle with the keys, i wait a couple seconds for the lights to go out that come on momentarily when the ignition is turned on, then i crank, but that's just out of habit nothing about electronics at all.
so my question is, is there any truth to this theory?
any explanations would be welcome, and this is my 500th post,just curious, wait 8 seconds to start? -- posted image.
Platinum - Posts: 13,723
Posted: May 27, 2009 at 4:58 PM / IP Logged
If it is a Petrol power plant, I have never heard of such.
ckeeler
Gold - Posts: 1,461
most mechanics are absolute quacks and bumbleing fools when it comes to anything electrical t&t. rather than take them all out cant you just offer to install a 528t on all the units and time them at exactly 8 seconds? even if you have to almost give away the part and eat the labor? at least you can possibly satisfy the customer, and maybe the grease monkey as well.
Posted: May 27, 2009 at 5:10 PM / IP Logged
Some Remote Start units are programmable for Diesel engines, that will give you a delay without having to buy anything, if those units are capable of that feature.
t&t tech
Posted: May 27, 2009 at 6:32 PM / IP Logged
yes my units are capable of the delay without additional parts, but the customer has insisted he wants it removed so we had no choice but to oblige, thanks for the quick replies guys.
lspker
Silver - Posts: 503
Posted: May 27, 2009 at 9:14 PM / IP Logged
If the delay was require it would be programmed in to the pcm or even the ignition switch itself.  Other than a desiel there would be no need.  I'd love to hear the mechanics resoning for 8 sec.
Posted: May 27, 2009 at 9:20 PM / IP Logged
He must ride bulls on the side.
tommy...
Gold - Posts: 1,901
Posted: May 27, 2009 at 9:21 PM / IP Logged
What a load of crap as stated, why doesnt the car do this...? I had a mechanic tell me that remote starters are bad for cars because all the accessory wires are powered up and over-heat...I asked what do people do when they are driving 8 hours to virginia beach...? So how much did you charge in labor to do this...Dont tell me free of charge...?
M.E.C.P & First-Class
KPierson
Platinum - Posts: 3,527
Posted: May 27, 2009 at 10:21 PM / IP Logged
The only time based thing to consider is the amount of time the fuel line takes to pressurize.  This is typically less then 2 seconds and a modern ECU may actually take longer to sync with the motor then the fuel pump takes to prime.
Something you may want to ask your customer -
1. How long have you been driving?
2. How many times have you started your car?
3. How many times have you waited 8 seconds before starting the car?
4. How many issues have you had related to that 8 second delay?
As stated above, if this was a real concern the car would have an interlock that would prevent it from starting.  If remote start units were damaging cars because they weren't waiting long enough the manufaturers would make the delay longer.  Currently, I believe the DEI delay is around 5 seconds or so from when the ignition is turned on to when the car actually cranks.
Kevin Pierson
ckeeler
Gold - Posts: 1,461
Posted: May 28, 2009 at 8:48 AM / IP Logged
good one. just curious, wait 8 seconds to start? -- posted image.
Friday, November 28, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
