sub and amp
haemphyst
Platinum - Posts: 5,059
Posted: May 29, 2009 at 7:23 PM / IP Logged
icearrow6 wrote:
haemphyst wrote:
Series is fine.
LOL. i like your laid back approach.
My laid back approach is a perfect match. 8 ohms will have that amplifier making easily 300 to 400 WRMS, which the woofer is perfectly suited to handle.
Don't swap the amplifier, so if you want to later, you can add an additional woofer, and still have the power necessary to drive a pair.
Additionally, the amp running at 8 ohms will run cooler, run more efficiently, run with lower distortion, and last longer. Leave the woofer wired in series, and enjoy. It's a PERFECT combination, just the way you have it.
icearrow6
Copper - Posts: 497
Posted: May 29, 2009 at 7:39 PM / IP Logged
I can't find specs on that alpine at 8ohms...thats all.
If you say it can make 300w RMS I believe you.
nickrusk
Member - Posts: 6
Posted: May 29, 2009 at 9:13 PM / IP Logged
thank yall for the help, my plan was to get another type-r and have them both ran to this amp, i thought i had it figured out befor i bought it, but i was wrong
haemphyst
Posted: May 30, 2009 at 12:15 AM / IP Logged
What happens when you halve the impedance, meaning go from 4 ohms to 2 ohms? The power comes close to doubling, right? For example: from 600 watts at 4 ohms to 1000 watts at 2 ohms. Well the exact opposite will happen if you double the impedance, from 600 watts at 4 ohms to ABOUT 300 watts (easily) to 400 watts at 8 ohms.
You don't HAVE to see a published spec for a given impedance that is higher than a typical load... Ohm's Law, baby! It'll do all the work FOR you!
