car alarm install.
jayrebb
Member - Posts: 6
Posted: March 25, 2003 at 1:20 AM / IP Logged
I am installing an eagle eye 90-902c, I have a few minor questions about a few things and any help would be greatly appreciated.
First off my car uses a negative pulse to lock and unlock doors, one wire for lock one wire for unlock, my question is do i need to run these wires through a relay to my alarm brain or can i hook the wires (that give a negative pulse from the brain) directly to the lock/unlock wires.   I wasint sure if i neede the relays, its got factory keyless (not the remote kind)
I would also appreciate any other comments or hints, i got most of this figured out just wondering about the keyless entry mostly. but if anyof you know anything about:
-good brain locations
-best way to tap into wires in a harness
-Oh...one more thing i really need to know, whats the difference between "door trigger neg" and door trigger pos." on the brain? is it just whichever my car uses or should i be using both
 thanks, Kenneth
draasch
Gold - Posts: 2,172
Posted: March 25, 2003 at 7:45 AM / IP Logged
what is the make and model of the car
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
jayrebb
Member - Posts: 6
Posted: March 25, 2003 at 8:01 AM / IP Logged
85 nissan maxima
draasch
Gold - Posts: 2,172
Posted: March 25, 2003 at 8:29 AM / IP Logged
Constant 12 volts WHITE/ BLACK IGNITION SWITCH HARNESS
Ignition 12 volts BLACK/ WHITE IGNITION SWITCH HARNESS
Starter BLACK / YELLOW IGNITION SWITCH HARNESS
Dome Light ORANGE / BLUE (-) AT COURTESY LIGHT OR AT RELAY
Trunk Pin Switch RED / WHITE (-) AT TRUNK SWITCH
Parking Lamp RED / WHITE (+) AT LIGHT SWITCH
Power Lock ADD ACTUATOR ACTUATOR NEEDED IN DRIVER DOOR #204
Power Unlock ADD ACTUATOR ACTUATOR NEEDED IN DRIVER DOOR #204
my notes say to add a motor to th edrivers door.
when you use a key to lock the drivers door, do all the locks operate?? if so then you need to add a motor to the drivers door.
Good Luck
David
Ace Security
813-376-9778
Tampa
jayrebb
Member - Posts: 6
Posted: March 25, 2003 at 8:45 AM / IP Logged
thank you for your help but i already have those wires  figured out, and my car had factory keyless, i got all factory actuators working.. but thanks for you help bro, Kenneth
draasch
Gold - Posts: 2,172
Posted: March 25, 2003 at 8:47 AM / IP Logged
did you get the door locks working?/
Good Luck
David
Ace Security
813-376-9778
Tampa
