dome light and door locks 05 tundra
cdrcrktx
Posted: June 02, 2009 at 5:31 PM / IP Logged
putting a standard prestige alarm in an 05 tundra excab not double. i am told that dome light wire is high current and i need a relay. i don t have any idea what type door locks i have, but i think i am going to need relays for that also. any direction would be great.
t&t tech
Platinum - Posts: 2,622
Posted: June 02, 2009 at 5:57 PM / IP Logged
i tried to post a wiring diagram but, i dunno what's happening, i'll get back to you,
t&t tech
Posted: June 02, 2009 at 6:02 PM / IP Logged
The door trigger wires are negative and found in the BECU above the driver kick panel. The colors are as follows. The LF door is gray/red, gray plug, pin 15. The RF door is lt. GREEN/ black, black plug, pin 8. The LR door is RED / white, gray plug, pin 16. The RR door is RED / white, black plug, pin 4. Use all four wires and diode isolate each. why do you want to use the domelight wire, do you want dome supervision?
t&t tech
Posted: June 02, 2009 at 6:05 PM / IP Logged
