reading wiring charts
noctorum
Member - Posts: 17
Posted: June 02, 2009 at 6:46 PM / IP Logged
From this wiring chart;
https://www.the12volt.com/installbay/alarmdetail/269.html
Am I correct in assuming that, for example with the Door Unlock, if the Blue/Red wire is grounded (due to the '-' at the end of the description) the doors would unlock?
tommy...
Gold - Posts: 1,901
Posted: June 02, 2009 at 6:56 PM / IP Logged
Yes...That wire requires a ground PULSE  to un-lock...
M.E.C.P & First-Class
noctorum
Member - Posts: 17
Posted: June 02, 2009 at 7:03 PM / IP Logged
I'm using an IC to control it, would 1ms qualify as a pulse?
Platinum - Posts: 13,725
Posted: June 02, 2009 at 7:14 PM / IP Logged
Probably going to take a whole lot more than 1ms.  250ms would be a better bet.
Tuesday, February 3, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
