trunk pop
emorse2323
Copper - Posts: 106
Posted: June 14, 2009 at 5:39 PM / IP Logged
I am trying to hook up an alarm on a 2006 mercury mountainer to a K9 Mundial SS and am having problems getting the trunk to pop open. Do I need a relay if so how does it need to be hooked up?
chev104275
Gold - Posts: 1,436
Posted: June 14, 2009 at 5:53 PM / IP Logged
not sure on that system but how do you have it wired up now ?    there should be a brown wire negitive trigger in the drivers kick panel     test using the switch on the tailgate   ive used this wire many times with no problems
Good luck Joe
emorse2323
Copper - Posts: 106
Posted: June 15, 2009 at 8:43 AM / IP Logged
Im using the truck pop wire from the car and hooking it straight to the (-Auxiliary output) from the alarm
chev104275
Gold - Posts: 1,436
Posted: June 15, 2009 at 9:07 AM / IP Logged
which wire how did you test it ? did you test your (-) output of the aux ?
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
