door popper on a sliding door
vibrationcustum
Copper - Posts: 171
Posted: June 21, 2009 at 6:41 PM / IP Logged
Ok here is the question. I have a 92 Dodge Caravan Le and I want to shave the door handles and put door poppers on the doors. I know how to do the 2 front doors but the question is can I put a door popper on the passenger side sliding door? This is not motorized so you have to pull it open. If any one has done it or knows if I can do it or not Please let me know. Thanks. If this is in the wrong forum sorry about that.
Can't be loud then don't have it.
(power acoustik system)
Head unit- TID-896 7" TOUCHSCREEN
ovn1-5500d 09 and another one coming soon
4-12" mofos 12ft3 box to 40hz (wall)
2 batterys, 1 power
soundnsecurity
Gold - Posts: 2,720
Posted: June 21, 2009 at 7:31 PM / IP Logged
anything is possible it just depends on how much work you are willing to do to make it happen. if it opens with a latch i would imagine it would be the same as the fronts you would just have to put things in different locations. now, making it actually open i think you would need some sort of actuator or spring loaded device. i would take the door apart and check if it can be done first before you tell someone it can be done.
vibrationcustum
Copper - Posts: 171
Posted: June 21, 2009 at 8:10 PM / IP Logged
It mine so I will do that and see if i can thanks
2 batterys, 1 power
vibrationcustum
Copper - Posts: 171
Posted: June 23, 2009 at 5:23 PM / IP Logged
Update:
Just got the door poppers on order and be here in the next couple days. will take pics of the install and maybe a video on how to do it.
2 batterys, 1 power
