how to charge a capacitor?
imupabove
Copper - Posts: 369
Posted: July 07, 2009 at 6:14 PM / IP Logged
I have a RFC1D cap. I have the charge card. And I'm having trouble with the directions. Can someone please walk me through on how to charge it? Thank you.
yimke
Copper - Posts: 417
Posted: July 07, 2009 at 6:39 PM / IP Logged
put the card between the terminals for 30 seconds with your fuse out of your power line.
Insert fuse.
Done.
imupabove
Copper - Posts: 369
Posted: July 07, 2009 at 6:49 PM / IP Logged
what do you mean "put the card between the terminals"? their are 4 wires on the charge card, blue, yellow, red, and black.
whiterob
Copper - Posts: 351
Posted: July 07, 2009 at 8:13 PM / IP Logged
Use the link below to see how to charge a cap with a charge card.
Click Here
imupabove
Copper - Posts: 369
Posted: July 07, 2009 at 9:49 PM / IP Logged
so connect the red wire to wire coming from my battery right?
and am suppose to ground the card's black wire? its so small.
haemphyst
Platinum - Posts: 5,059
Posted: July 08, 2009 at 1:32 AM / IP Logged
The charge current will be very small. Thas small wire will be perfectly adequate for charging the cap...
yimke
Copper - Posts: 417
Posted: July 08, 2009 at 6:58 PM / IP Logged
Look on the bottom of the card. There is an outlined piece of metal for each terminal of the capacitor and it is connected properly to the circuit already. You don't have to use the wires. They are used for general purpose capacitors, or RF caps that don't have top mount terminals that fit.
Friday, February 20, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
