heated seat in '91 nissan maxima
*chit*
Member - Posts: 12
Posted: July 20, 2009 at 9:09 PM / IP Logged
wanting to install heated seats elements into my '91 maxima. are there any tricks i should know or is there a proper route i should follow in regards to the wiring?  any hints will be appreciated.
Platinum - Posts: 13,671
Posted: July 21, 2009 at 11:25 PM / IP Logged
Are you purchasing some kind of kit?
*chit*
Member - Posts: 12
Posted: July 22, 2009 at 9:42 PM / IP Logged
I have no kit i just ended up with the seat elements out of a wrecked murano and considered installing them in my car if not too much hassle involved.  Do those pads run full twelve volts or are they run down to much less?
Posted: July 22, 2009 at 9:50 PM / IP Logged
How many elements do they have in each seat?  Are there 2 wires per element?  I am sure that on High they are fed 12 volts.
*chit*
Member - Posts: 12
Posted: July 26, 2009 at 11:02 PM / IP Logged
Awesome thanks.  It is two seperate elements (back and bottom)  joined by the wiring harness which ends in a three wire plug.  Once i figure which wire does what they'll be goin in.
Posted: July 26, 2009 at 11:32 PM / IP Logged
Chances are there is a common ground and a hot for each element.  Do you have an Ohm meter?
*chit*
Member - Posts: 12
Posted: July 27, 2009 at 6:39 PM / IP Logged
Yes i do and that will tell the tale.
Thursday, May 9, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
