slot port dimensions
dodoandduck
Member - Posts: 14
Posted: August 06, 2009 at 3:37 PM / IP Logged
I was wanting to know how to calculate Slot port dimensions. I have three Audiobahn AW1000v's which call for a 3" diameter port 8" in length. I'm building a shared airspace fiberglass box with 4.5 cu total airspace and want to configure a rear firing slot port. Thanks for the help.
Platinum - Posts: 13,670
Posted: August 06, 2009 at 8:19 PM / IP Logged
A 3 inch circle has 7 Sq Inches of surface area.  A 2 X 3.5 inch port the same length will be the same as the 3 inch round port.
Formula to figure the surface area of a circle is   Pi (3.14159) X Radius Squared.   3.14159 X (1.5 X 1.5)  =  7.068
Surface area of a slot = Height X Width.  2 X 3.5 = 7
dodoandduck
Member - Posts: 14
Posted: August 08, 2009 at 6:54 AM / IP Logged
Very cool. Thank you. So a slot port 2" high 10.5" wide and 8" deep would be the same as ( 3 ) 3" by 8" round ports. Appreciate the help.
DYohn
Moderator - Posts: 10,741
Posted: August 08, 2009 at 11:40 AM / IP Logged
This is incorrect.  3X 3" X 8" ports will tune to a higher frequency than 1X  2"X10.5"X8" slot.
dodoandduck
Member - Posts: 14
Posted: August 13, 2009 at 6:59 AM / IP Logged
Ok, so what would be the correct calculation then. Thanks for the help. I'm looking to tune to 35.424 in a 3.750 cu/ft enclosure.
DYohn
Posted: August 13, 2009 at 8:30 AM / IP Logged
Use the calculator on this site.  And realize your actual tuning will never be so precise as 35.424 Hz, although you can cewrtainly enter that into the calculator.  35 would be your target.
Tuesday, May 7, 2024 • Copyright © 1999-2024 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
