2001 Sebring Convertible
BudH
Posted: March 27, 2003 at 10:26 PM / IP Logged
I need a complete wiring diagram for a 2001 Sebring Convertible with Infinity Audio system
Thanks in advance
draasch
Gold - Posts: 2,172
Posted: April 06, 2003 at 10:38 PM / IP Logged
Constant 12 volts PINK/BLACK, RED / WHITE & RED * IGNITION SWITCH HARNESS
Ignition 12 volts D BLUE IGNITION SWITCH HARNESS
Starter YELLOW IGNITION SWITCH HARNESS
Dome Light YELLOW OR BLK/YELL (-) AT LIGHT OR ILLUM. ENTRY RELAY **
Trunk Pin Switch TAN/BLACK (-) AT SWITCH, LIGHT IN TRUNK, OR BCM ***
Parking Lamp BLACK / YELLOW (+) AT SWITCH
Power Lock WHITE/ L GREEN 20 PIN BLACK CONNECTOR #217
Power Unlock SINGLE WIRE SYSTEM AT BODY CONTROL MODULE ***
* Take Caution When Hooking To Power Wire Due To Fuse Rating On Wires. PINK/BLACK Fused At 40A, RED / WHITE Fused At 10A, and RED Fused At 20A. ** Illuminated Entry Relay Loacted Behind Dr. Dash Right Of Column. *** Body Control Module (BCM) Located Behind Dr. Dash Left Of Column. #217 - See Single Wire Resistor Door Lock Diagram.
Good Luck
David
Ace Security
813-376-9778
Tampa
Donate to the 12volt
