automatic window roll up
linc00
Posted: August 10, 2009 at 1:24 PM / IP Logged
I just purchased a python 990 remote start alarm since its two way i know i can have the window roll up controled by the remote my problem is i dont know where the window module is and what wire to tap in to and if there positive or negative polarity can some one please help me
00 lincoln ls
xicano21
Member - Posts: 32
Posted: August 10, 2009 at 2:22 PM / IP Logged
If you can control the windows when you lock with the key and unlock with the key, then you can extend the door lock pulses, its a matter of programming the alarm. They should be negative
linc00
Posted: August 11, 2009 at 9:54 AM / IP Logged
i understand wat your saying. so if i hold the lock button on my alarm controller will it roll them all the way up
00 lincoln ls
KarTuneMan
Platinum - Posts: 7,056
Posted: August 11, 2009 at 10:19 AM / IP Logged
Simply locking will NOT roll the windows up.
